Posted on Jun 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tx-v940 I hooked up new speakers wrong and now the unit doesn't work... Can anyone help me....? Please....? Scott
Francisco Mauricio G
Level 3:
Genius:
  • Onkyo Master 1,551 Answers
  • Posted on Jun 11, 2008
Onkyo Master
Level 3:
Genius:
Answers
1551
Questions
Helped
524982
Points
4192
If you don't got any sound the audio amplifier IC is damaged you gotta change it.Good luck
My onkyo tx-v940 has very low volume. Has anyone had that issue before? How did you resolve it? Is there a reset option on this unit?
My onkyo tx-v940 has very low volume. You should
Check the voltage supply to both +B and -B voltage.
If both voltages are low, the voltage amplification via
differetial and voltage amps will be low. Finally, low
Volume due to power = VI. If V is low, so does power
Output. The negative voltage can also be measured as that of +B with black probe clamped to heat sink
by a crocodile clip.
6977e902-8520-4594-86f0-eb3d35bd2b72.jpgschematic. jpg-5pfgdpze0xsybax2zren2sji-2-2.jpglarge capacitors-5pfgdpze0xsybax2zren2sji-2-3.jpg
I am not getting sound from the left speaker channels (A and B) on the onkyo tx-v940. I tested wires and switched speakers.
Hi, Are all of the left side speakers out? If they are the receiver would need to be serviced. Thank you, Onkyo USA
Onkyo tx manuals
http://www.manualslib.com/manual/302311/Onkyo-Tx-Sv414.html#product-TX-V940
Protect mode. will it work again? how can "i" fix
This indicates a load on the system, turn receiver off, remove speaker wires from the back of the unit. Now power up and turn volume right down, if the word protect stays off, there is a short in the wires or one of the speakers. But if the word protect comes on, "with wires and speakers dis-connected, it means there is a short in one or more of the audio outputs in the receiver. If you are handy using a digital meter then you may be able to track the shorts down, and replace the parts to get it up and running, also if you can solder then it will make the job easier.
2answers
I own a onkyo skw 980 subwoofer and it just quit. I have only had the system for a month or so. I was listening to music, not loud and the bass (sub) just stopped. No crack, pop, or blown speaker. The...
How are you sourcing the program material to the sub? This TX-V940 receiver doesn't have specific sub support.
=== Just the same...
You need to first determine which is at fault - the sub or the receiver.
Connect the Sub Input to Tape Rec on the receiver (but DO NOT select Tape) and see if the sub reacts to your playing FM, for instance. If it works you need to go back to the receiver and the unknown method you're feeding the sub.
You could also test the sub with a CD player output but use a recording that starts low because you won't have volume control.
TX-V940 only comes on with standby/receive light on nothing on display
I HAD ONE AND IT DID THE SAME THING ONE OF THE BUTTONS WAS STUCK SO CHECK ALL THE BUTTONS AND IT SHOULD COME BACK ON IF THE STAND BY LIGHT IS ON
I am frustrated. I would like to hook up my new mandatory unit and it is not working. Please tell me where I can find the step by step instruction for hooking this thing up.
take it all apart. start with just an antenna and 2 speakers. turn on the tuner and see if it works. go from there. check the speaker switch, make sure they are on
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
