Question about RCA Televison & Video
Tv wont come on
Hello
60" RCA flat screen, 14 months old. Acts like it is the bulb, but no audio
  • 927 Answers
Good Day,
If you use your TV a lot then you need to replace the lamp, but if you only use your TV about 8 hour a day, then you also may need to replace the ballast.
The lamp is really easy to change. You should get at least 5,000 hours on your lamp.
Call RCA customer service and ask for a concession to replace the lamp and ballast. This is a common problem for RCA!
Good luck, God Bless.
Posted on Jun 11, 2008
How do Ifind out if my 18 month old tv is covered by any type of recall. It flashes light constantly.
Your probably out of luck. once the warranty period is over you pay for any repairs. You can contact an authorized RCA servicer in your area. They will know of any recalls.
Feb 23, 2015 | RCA LED32B30RQ 32" LED TV 1366x768, 60 Hz,...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Sharp aquos 60
set comes with at least 90 days labor and one year parts warranty----new or refurbished unit?
Mar 12, 2012 | Televison & Video
14MG135 4:3 14" Television 14 in. Is this a
No this is not a digital tv. You will need a converter box/set top box. I am posting the specifications. Where it says tuner it would have to say atsc and/or qam for it to be a digital television
Product description Product Identifiers Brand Thomson Model 14MG135 MPN 14MG135
Key Features Screen Size 14"
Technical Features Screen Type Non-Flat Screen Aspect Ratio 4:3 Built-in Tuner NTSC, PAL, SECAM Adjustable Color Temperature Without Adjustable Color Temperature
Connectivity Front Input Connectors Audio (RCA) x 1, Composite x 1 Rear Input Connectors RF x 1
Audio Features Number Of Speakers 1 Speaker Power 1 x 3.5 Watt Audio Type Mono Subwoofer Without Subwoofer Audio Leveler Without Audio Leveler
Miscellaneous OSD Languages Danish, Dutch, English, Finnish, French, German, Greek, Italian, Portuguese, Russian, Slovakian, Spanish, Swedish, Turkish Parental Control Proprietary Sleep Timer With Sleep Timer Remote Control Standard Additional Features Headphone Jack
Jul 19, 2011 | Thomson 14MG135 14" TV
White line only, has sound, may be 14 yrs old.
Hello
If there is a white line across the screen, the vertical output section of your TV is faulty. If the line is vertical at the middle of the screen, horizontal deflection yoke doesn't get sweep signal. You haven't mentioned about the full mode number of your RCA TV. Therefore I can only give you this much hint. OK.
Mar 06, 2011 | RCA Televison & Video
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
No sound on LCD tv
in the audio part of the menu, check to make sure the internal speakers are not turned off.
what connection are you using for the DVD? if using YPrPb, make sure you also have the audio red and white plugged in
Feb 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Clicks but no audio/ video
answer is buy new tv, LOL.
Oct 19, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
