Question about Refrigerators
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Posted on May 25, 2015
  • 356 Answers
SOURCE: my mini fridge freezes everything
Need to replace the termostat.
Posted on Apr 03, 2009
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: have Kelvinator Cyclic 500 Fridge, Does not seem to defrost prope
has the thermostat been replaced? if so it is probably the wrong 1
SOURCE: kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Posted on Nov 08, 2009
SOURCE: Kelvinator 330 impression series fridge leaks
The drip tray is blocked, open your door, about half way down at the back you can see the drip try, on the Right hand side there is a hole where the water drains, poke a plastic straw down there to clear.
Posted on May 16, 2010
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
No matter what temp setting I adjust my fridge to it freezes up within hours. I now have a giant freezer. Where do you think the problem lies. I want my fridge back. It is a Kevinator Impression Series...
In spite of keeping the temperature regulator 'Low' mode if it freezes up so fast, that means there is a problem in the freez pipe from where the cool air is coming into the freezer. Please check on that. Make sure, that u defrost it once in a week.
thanks,
saumya.
Jul 13, 2009 | Frigidaire FRT15G4B Top Freezer...
Kelvinator Opal CS 390 F door has dropped down on handle side.
Apr 26, 2009 | Refrigerators
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
