If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
try using a pc with card reader / writer to format the memory stick pro duo and then try it again in camera it should work........If you have troubles formatting the same using a PC as well check if gets detected as removable disk and then try using a antivirus to scan it and if you find any virus, remove it first and then format it. it should then work.............
Hi,Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera.Formatting Memory card**you should always format a new memory card or one from which you wish to erase all images and other data.** Please note that formatting a memory card erases all data, including protected images and other file types.1. (Set up) Menu [Format] 2. Select [OK] and press FUNC SET button.Low Level format, recommended by cannon Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
1:friend connect the mobile to the PC and select mass storage option go to my computer and right click on the memory card Icon click on format select full format option . the above solution will solve your problem if the error is coming because of bad-sector 2:some times these error comes if there is a code to THE memory card.
3:the memory card is faulty or is infected with virus
The card needs to be formatted in the camera, not on the computer. Try going into the camera menu and find "reset"...follow the on-screen instructions.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card.
(Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
