Question about Panasonic PT-52LCX66 Projection Television
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
How and where do I clean this air filter. Message pops up saying it needs cleaning and that tv will shut off in 1 minute. I have looked on line and solutions include using remote with SWAP/STOP key but I don't have that on remote. Manual is NO help
  • Anonymous Apr 12, 2009
    pops up on tv air filter needs cleaned will turn off in 1 min. took the tv apart still cant find anything that resembles an air filter
  • 927 Answers
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Posted on Jun 11, 2008
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
Tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
Tip
Panasonic PT-52LCX66 Manual Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Have you lost the Operating Instructions for your Panasonic PT-52LCX66 Projection HDTV?
Click here to download a digital, searchable copy of your users manual / owners guide.
I hope that helps.
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-52LCX66 Projection Television Logo
607 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
