Question about Nintendo Wii Console
Changed battery in remote and now it won't connect
Changed battery in remote and now it says press "A" to connect but the remote lights are not lit and it will not connect?
  • 52 Answers
You will have to click within the battery area there should be a red button also in the front wear the sd memory cards are should be click the red button also.
Posted on Jun 11, 2008
The remote won't work with tv and the batteries have been changed
Most TV shops can test the remote to see if sending by pointing the remote at it and pressing buttons.
Many digital cameras in a dark room will react with a tiny flash of light on the camera display when the remote is pointed at it and buttons pressed.
The remote may also if not working be repaired by most shops--we get 5 dollars if we can fix one--usually easy money.
Oct 30, 2012 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
Hi, My cordless mouse does not work. I changed the batteries. The green light is lit on the bottom of the mouse. I tried resetting it. Can you help? Sue
It sounds like you have to re-pair the mouse. Press the "connect" button on the signal receptor then press the "connect" button on the bottom of your mouse.
Mar 01, 2011 | Logitech Cordless Mouse
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Sat button on remote stays lit and it won't let me do anything in just stays lit. I have even changed the batteries
jsblondie316
If the light stays on and you have already replaced the batteries, then the remote needs to be replaced. Please call 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Jan 14, 2010 | DISH Network 142923 Remote Control
What is thecode for rca tv
Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
I changed batteries in my remote and i cant figure out how to reprogram it
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 13, 2008 | Philips Universal PH301S Remote Control
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
