Question about Tappan TGF320 Gas Kitchen Range
Tappan Range 560S111PO1 Timer buzzer won't turn off
The buzzer for the timer on my stove keeps going off.  I can't get it to stop.  I'd like to disconnect it, since I never use it.  Please help!  The buzzing is driving us and our neighbors crazy.  Thanks.
Please note:  I couldn't find my product listed, so I just picked the first Tappan gas range from the list, otherwise my question wouldn't go through.  The correct model number is 560S111PO1, which must be an old model.
  • Anonymous Oct 10, 2008
    idk wat the name of my stove is..but the buzzer wont stop going offf...
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Tappan Range 560S111PO1 Timer buzzer won't turn off
You have to set the timer alarm just right on the 12 'o clock position or .........................BZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Posted on Jun 12, 2008
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
The buzzer won't turn off.
First try to unplug it and give it 5 minutes and then plug it back in. If that doesn't work then you'll need to check the wiring with it unpluged. If there is nothing obvious then you'll have to replace the main board..... also knows as a ERC or Electronic Clock Timer
Number:
316222802
Substitution: 316455410
Jan 30, 2011 | Tappan TGF320 Gas Kitchen Range
I have an older stove and the kitchen timer buzzer keeps going off...at random times...i have never actually used the timer
un plug stove, pull cover off . if you dont use it unplug the timer wire put wire nut on it. and call it a day.
Apr 11, 2010 | Kitchen Ranges
Oven buzzer won't stop. F-1 is flashing.
http://www.applianceaid.com/fault_codes.html#f1test
May 15, 2009 | General Electric Stove/Oven/Range Chrome...
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Dec 21, 2008 | Viking Stove/Oven/Range Timer Knob -...
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Jun 12, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
341 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
