Question about Refrigerators
The freezer is ok but the frige is not cold - Refrigerators
  • Anonymous Jun 11, 2008
    Heb een koel-vrieskast,het vriesgedeelte doet het goed,maar het koelgedeelte doet het niet.Het is een Bosch exclusiv cooler.
  • bshipley66 Aug 18, 2008
    Dometic propane refer section is running warm 45-50 deg. Ice ball forming on right hand of cooling fins in refer. Fridge is in a cabin application, ambient room temp is about 75 deg. There appears to be a good door seal
    unit is 1 year old
  • 828 Answers
Sorry but I understand English only. Have checked for a defrost system problem.
Posted on Jun 11, 2008
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
Freezer fine frige to cold
you must check the door seals are ok and if they are you might have a bit of compressor oil stuck in the condenser pipes somwhere this is a regular problem with alot of new fridges youll need to take it to the agents if thats the case
Mar 20, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is working Ok but the fridge is not getting cold
defrost your frige and freezer .reason is it builds up ice in back after awile it cannot get air flow til it gets turned off a couple hours.you will have some water to clean up
Mar 01, 2010 | Refrigerators
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Refrigerator cold but not cold enough. freezer
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 06, 2009 | Refrigerators
Frige freezing solid
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frige not cold,freezer working ok
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. Look at the heater. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
May 31, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
