Question about SanDisk Sansa e250 MP3 Player
How to restet my sansa e260
Hey man do you know how to reset a sandisk sansa e260 to factorie settings
  • 8,596 Answers
Menu - Settings --> Reset All
This option will reset all the Sansa e200 player’s settings back to
factory defaults.
Posted on Jun 13, 2008
Ive a e260 v2 . which ive had since 2009. I was very pleased with the player Someone said the other week that i should Update the Firmware . So i did download the firmware search and it uploaded it,...
Hi, it might not be from the firmware update that the volume gets low.It might be from the speaker already getting bad without you noticing it. you can replace the speaker too it might work out.
Also firmware update can cause it too. Updating with the wrong firmware ...
You can use the below link to know the right firmware update to use for you san disk sansa e260 mp3 player..e200 might work with yours..
kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
1. Download the SANSA Updater from:
sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
Hope it helped.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e260 MP3 Player
My e260 gets to the refresh database screen and starts to fade out to a white screeen and restarts
1: RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
2: Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
3: Recovery Mode also resets system settings when unplugged... lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software
Apr 05, 2010 | SanDisk Sansa e260 MP3 Player
I think that my sansa e260 have a virus, which could be the solution?
Reset All
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 is non responsive
�� Reset All
will be gone......PLease RAte
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
I would like to reset my sandisk sansa e260 mp3
Apr 09, 2009 | SanDisk Sansa e260 MP3 Player
When i start up my SanDisk Sansa E260 it starts then resets
I had the same problem when I connected to the computer. So I used my friends Labtop definite 2.0 usb. Did you try to update your sansa click on link and download install run connect sansa when asked.
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
I hope this works
Feb 19, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260 4GB Media Player manual
http://www.sandisk.com/sansa/#/support-0/
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Check the users manual for this series and see how to reset it. hopefully thats all thats wrong. otherwise you can send it in for warranty repair.
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
Dec 19, 2007 | SanDisk Sansa e260 MP3 Player
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it doesn't then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
336 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
