Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Head of mixer droops
The head of the mixer is drooping some what and I have to lift the head slightly to lock the head down and it is wobbly at high speeds, something inside has slipped maybe? Solution?
  • famotala Jun 23, 2008
    as above
  • Anonymous Jul 25, 2008
    I have the same problem (mixer head droops). If I don't find a fix soon I think I may operate!!
I just fixed mine this moring!!
Solution:
1- Lift head. In the lifted position you will see the head of an adjusting screw. Turn it to the left say a half turn.
2- Lower head and see if it is still too low. If so, do it again.
I had to turn mine like two plus full turns.
I beleive it goes into a nylon insert so that the threads are cut as the screw is put in the first time. If the screw is too loose, it may be possible that over time the head could slowly drop because of vibration and the screw slowly moving inward again. If that happens, a new nylon insert may be needed (but that is a different story).
There is another screw that may be loose of the head moves too much right and left. I also had that issue. This screw will be seen if you lay the machine on its side and look up the shaft (pedestal) of the base (large empty area the head attaches to). You will see a small screw head (first item up the open part). That set screw holds the unit in position on the hinge pin to stop movement from right and left.
You will find a full service manual in pdf at:
http://www.mendingshed.com/kitaidparts.html
Hope this helps.
Ken
Posted on Jul 25, 2008
  • jkriho Apr 01, 2011
    This worked! yea!
  • EHDunne Jul 16, 2011
    My experience:
    Originally my issue was a wobbly head - shifting right to left on my 3.5 year old Artisan Series. In an effort to solve what I perceived as something being loose I tightened up all the screws I could see (except the one that actually fixed this - because I sure didn't think to look underneath it for something that would effect the top). Not knowing that the height adjusting screw was, I tighten it all the way to the right. This of course didn't fix the wobble and instead led to not being able to use my wobbly headed mixer at all because now all the attachments were hanging down too far & hit the bowl!
    I'm so glad I found this post because I was able to completely fix my mixer without any disassembly & simply using a screw driver.
    I did have trouble figuring out what screw was being described the loose head solution. The description make sense now that I know where it is, but I spent a while looking at the outer side of the shafts. So, for others using this who may not understand it: the screw is underneath the mixer. When you lay the mixer on its side, look up inside the hollow bottom.
    Thanks for posting this Ken!
SOURCE:
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
Aug 08, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Head won't lift without force. The head lock is in the Unlock position but it doesn't lift up easily. I have to stand behind the unit and use a lot of force to pull it up. It was fine one minute...
Presuming all looks OK near pivot & lock mechinism? can you see the locking hook in rear of mixer head at the hinge area directly behind lock lever, and is it nested in the slot on the base, or is it jamming up outside the stand and scratching it up?
There is a flat-head height adjust screw to control clearance between spatula and bottom of bowl visible from head-back position- leave it alone. There is a headless set screw visible when mixer is upside down to hold the pivot pin secure. This must be loostened with long-shaft flat screwdriver to remove the pivot pin for head removal if necessary ---avoid removing the pin if possible.
Is the hinge stuck with film of sticky sugar, milk-glue residue, ot the like? That is most common cause, distant second is the lock mechinism alignment (very rare)
Its important to keep head from wobbling side-to-side in use, so dont file or sand anything
Can telephone 609 213 2222 if necessary no charge for my talk.
Oct 16, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid tilt head lock keeps coming loose while beating small amount of dough allowing the head to wobble gradually bad? This is the second mixer with same problem! I've heard some people talking...
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Jan 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
Mar 28, 2010 | KitchenAid RRK150 Stand Mixer
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
I need to lift the head a little. the wire whip
Hi LEDAVETORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Turn scre3e30899.jpgw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
Mixer Head Wobbles
Fixed it!!! My mixer had the same problem.  It was a hand-me-down...
Okay, so I lifted the head and looked down into the pivot where there is a screw (looking from the front of the mixer).  I took a flat-heat screwdriver and turned it counter-clockwise.  (It took quite a few turns, the screw came out a few millimeters.)
BUT when I lowered the head, hurray!  No more paddle rubbing against the bowl!  No more head jumping up and down!  No more wobbling in the "locked" position!
Try it!
Jan 13, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
1,159 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
