Question about Toshiba Computers & Internet
My computer is not turning on. I just wanted to know if it is a problem with the motherboard or simply the HD. When I press the turn on button, the computer turns on, the cooler works, but i can't see anything on the screen. If you could please tell me what to do, I would appreciate it.
  • 70 Answers
Check if you can hear any beep sounds, if you hear a long continuous beep sound, remove the Memory on you Motherboard and clean it with a dry brush then place it back again, be sure you place it as how you remove it, make sure the lock knob on each side of the memory slot firmly locks. If you hear a very short continuous beep sound remove the Video Card then clean it with dry brush and place it back again, make sure it sits tight on the slot.
Posted on Jun 11, 2008
How to get into menu of American Megatrends Inc. P13 after windows already started?
Nope.
Need to get into the BIOS Setup utility, BEFORE Windows comes up.
Does go by pretty F-A-S-T, huh?
(And they're off...........they're neck and neck, and coming around turn 5...............it's Magic,....no it's Blackjack........no it's..........)
Do I assume you have the - enter BIOS Setup key?
OK.
AS SOON AS you press the Power On button, start tapping on that key.
Tap in 2 second intervals.
Hear beeps?
Ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | Computers & Internet
Broken power button
The power button has 2 wires conected to it. All you have to do is to take these wires and simply join the two wiresfor a second or two, until the computer starts. after that you letthem go so they do not touch because it will turn your computer off, like when you keep the power button pressed continuasly
Dec 05, 2012 | Computers & Internet
Hello, my 8gb Sandisk light is keep flashing and is not bieng reconized by my laptop.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
good luck.
Feb 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have pendrive with 32 gb. It was worked for 2 days only. Now its not recognizwd by windows. what can i do.
Considering that if the USB is fine and and working systems, here is simple solution! Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that?s it! Note that this does not mean just turning off your computer because modern computers don?t really turn off when you press the power button as the motherboard still gets power. First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be ?rebooted? also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices! So, first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Remove the battery and press and hold down the Power Button of your laptop for a few seconds. Let it sit for about a minute and then plug it back in. Hope this helps someone fix that ?USB device not recognized? Windows error!
Otherwise if the USB is faulty you may claim the warranty as the USB Pendrives are usually under 10 months warranty cover.
CreativeTECH
Jan 03, 2011 | Computers & Internet
Usb not recongised
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
The motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in. (VOILA)
Nov 28, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
I just want to know to turn on my TravelMate Laptop computer. I want to where the start button is? Simply as that.
You will find a key that has C facing upwards with an I in it. This is the power on switch.press it lightly. Three LEDs will turn green for a moment and then some more LEDs with start blinking. And finally you will get the Windows desk top.
Nov 08, 2009 | Acer TravelMate 4150LCi Notebook
Can't turn moniton on
1.) Did the computer turn on?
2.) Is it unplug or plug to electicity outlet?
3.) Is it properly connected to right video card?
Feb 08, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
My computer is not turning on. I just wanted to know if it is a problem with the motherboard or simply the HD. When I press the turn on button, the computer turns on, the cooler works, but i can't see...
plz resit the ram,if problem is not solved then try by removing the cable from the monitor to cpu and check is there is any message or white screen in the monitor,if you get any thing then your monitor is ok,otherwise your monitor needs repairing.
If you get message in the monitor or the color changes then your motherboard display adapter needs to be repaired
Jun 11, 2008 | Intel Motherboard
Need answer asap
try this.. removed the bios chips on the motherboard ..try to was your motherborad w/ dishwashing liquid soap then blow dry the motherboard and let it dry for 1 day ..after 1 day put again the bios on your motherboard then try to turn on your motherboard and check if it has the power again..
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Just purchased this motherboard, can't get bios to boot
just be sure...
take out everything, except the the power cable and the little speaker. try to turn it on. there will beep sounds. if not, the problem is the board. if there's sound, check connections.
also tell me the model of it, if possible.
after turning it on, check the power and hd leds, if they are on, or blinking.
check if hd and dvd are both jumpered as master. try removing both, just to try to get the bios working.
and one last thing, check it there's a intrusion jumper on board, if yes turn it off.
Computers & Internet Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
