Question about Pioneer AVIC-D3 Car DVD Player
Hola tego un problema con mi pioneer avic-d3 ordene el dvd del navegador y lo istale funciono perfecto pero al cabiar el leguaje de ingles al espanol ahi empeso el problema que ara no funciona nada ni el radio solo dise que inserte el disco a propiado si alguien me puede ayudar selo agradeseria munchisimo gracias
hogan doan
  • 227 Answers
SOURCE: Pioneer AVIC-D3
$4.99 on Ebay.
Posted on Mar 05, 2008
hogan doan
  • 227 Answers
SOURCE: help...
Look really hard on avic411.com. Goodluck buddy.
Posted on Mar 06, 2008
SOURCE: How do you pair an LG Dare phone Bluetooth to Pioneer Avic Dz3 unit
make sure your phone is in discovery mode so it can be seen by bluethooth device, I had the same problem with my lg voyager
Posted on Sep 12, 2008
hogan doan
  • 227 Answers
SOURCE: i have a problem with
You can get the most current up to date copied version on Ebay for about $15-20. Goodluck.
Posted on Dec 03, 2008
  • 69 Answers
SOURCE: my pioneer indash avic d3 wont play dvd's you
this until has a safety feature installed that will not let you view video while in motion. it has a light green wire on the back that is supposed to be connected to the cars ebrake wire so that in order to view video you would have to have your ebrake ingaged. it also allows you to be able to type in address for the navigation. if this wire is not connect or not connected properly, you will get a messages that says drive can not view video will driving..
double check the connection....or you can just bypass it completely. i have attach a link on how you bypass this feature which will allow you to watch video and type in nav address while drivin
http://avic411.com/forum/viewtopic.php?f=11&t=7998
Posted on Aug 15, 2009
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hola, tengo una computadora acer aspire one, al encenderla me sale un letrero diciendo que se ha producido un error en el disco que pulse ctrl+alt+del para reiniciar el equipo, pero al hacerlo sigue...
Puedo ayudar, pero, no puedo hablar el espanol mejor. Si tu tienes un dispositivo de U. S. B. en la computatore, puede causar esta problema. Si usted elimina el dispositivo antes de la puesta en marcha, puede ayudar.
Ingles es mi idioma primera, lo siento.
Jul 13, 2010 | Acer Aspire One PC Notebook
1. se enreda el hilo abajo y se rompe el hilo de arriba. 2. muy baja tensión del hilo de abajo. está en el límite de ajuste. Ajusté la bobina y mejoró pero sigue con el problema...
Hola! Espero que puedo ayudarle con su problema--pero, como hace mucho tiempo que no escribo en espanol, por favor, tenga paciencia conmigo.
Muchas veces ese problema de enredar el hilo del abajo resulta de la presencia de pequenos pedacitos de hilo en esa zona. Use un pequeno cepillo para saquar toditos.
Generalmente, no hay que adjustar la tension de las canillas (bobina?). Adjuste al punto que hay un poco de tension cuando jale un poco al hilo.
Casi siempre adjustando la tension de arriba solucionara todo.
Use hilos de diferente colors en la canilla (bobina) y arriba. Tambien, es major usar un aguja nueva. Usando un pedacito de su tela normal, empieza a coser. Cosa unos centimetros, y pare para cequear. Siempre adjuste la tension con la pie prensatelas abajo.
Si se ve el hilo de abajo (el del bobina) en la parte superior de la tela, el hilo superior esta demasiado tenso. Gire el equilibador de tension para disminui el numero.
Si el hilo superior esta demasiado flojo, se ve el hilo del bobina en el lado inferior de la tela. En ese caso, hay que amentar el numero.
En todo caso, hay que hacer las correciones lentamente,
Sequn mi guia, se rompe el hilo de la aguja:
1. No esta enhebrado correctamente 2. La tension del hilo de aguja es excesiva. 3. La aguja esta despuntada o doblada 4. La aguja no esta bien colocada. 5. Los hilos de la aguja y del bobino no estan bien colocados debajo del prensatelas al empezar a coser 6. La tela no se ha extraido hacia atras al terminar la costura 7. El hilo es demasiado grueso o fino para la aguja.
Ojala que eso le ayude y que mi espanol no esta demasiado feo.
Robbie
Feb 22, 2010 | Kenmore Sewing Machines
Hola a todos, tengo un problema con el icono de la bateria de mi portatil. este desaparecio de un dia para otro y no hay caso de volverlo A Mostrar. en las Propiedades de la barra de tareas y menú...
lo siento, pero mi espanol no es muy bien. Para este problema, nescecitas vas al "Control Panel" > "System Settings" > "Power Settings". Perdon, pero no conozco este nombres en espanol. Tengo windows en chino y alman, pero no espanol :P.
Primero cambiar este cosas, y despues propiedades de la barra.
Jan 09, 2010 | Microsoft Windows Vista Home Premium...
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Apr 06, 2008 | Sony Ericsson K750i Cellular Phone
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
Pioneer AVIC-D3 Car DVD Player Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
