Question about Sony UP DR100 Thermal Photo Printer
Printer Would TURN OFF When SCSI Cord is Hooked Up to the laptop
I just got my refurbished printer and  tried to hook it up. When I connect the power cord to the outlet and turn the printer on, the printer turns on.
But as soon as I connect the printer and the computer through
the provided SCSI cable, the printer TURNS OFF.
I tried different power outlets, thinking that might be the case, but it
keeps doing the same thing.
How can I solve this problem? My first job is next Saturday and I really need the printer to work.. I'm about to cry..
Hi you are connecting it to the wrong port you are probably using the printer port and you need a scsi port the printer is just shuting off so that it won't cause damage to yourself one you change the connection the printer, after having it unplugged for atleast 5 minute will start up and stay on just fine Good Luck
Posted on Jun 24, 2008
My printer is hooked to my laptop but when I click on something to print it will not print anything.
Are you able to make copy standalone ?
If yes, follow the steps on your pc
Click on start button
Click on Control panel
Open Printers and Faxes Folder
Check if there is any documents stuck in Queue on the printer icon
If yes, Right click on the icon and click Cancel all documents, ( do it 2-3 times )
Refresh the page by pressing F5 button on keyboard.
Disconnect the printer power cord, Restart your PC and connect the cord.
Try to print
Regards,
Ron
Mar 24, 2011 | HP Officejet 4215v All-in-One Printer
My HP all in one wont turn on since I hooked it up to my new Mac.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr18
Aug 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Not working?
You'll need to install the copier drivers to your laptop to get the print options to function. Don't confuse fax functions with printer functions. Having the unit hooked up to the phone line allows you to send and receive faxes. You need to be hooked to your PC/laptop with the proper print drivers installed in order to print.
Aug 03, 2009 | Brother MFC 7420 All-In-One Laser Printer
I've inherited a lexmark x3480 printer. It appears to be power cable-less, but it won't turn on when I hook it up with the usb cable to my laptop - the laptop doesn't recognise it either. Do I need to...
The printer should have some sort of power to boot it up. I would go to the Lexmark website and order a power cable for it. Just put in your model number etc. to locate the correct cord for it. Good Luck!
https://parts.lexmark.com/wpo-catalog/US_en/power_cords
Mar 08, 2009 | Lexmark X3480 All-In-One Printer
Lexmark 4200 all-in-one problem
I got my old printer hooked up last night. THANKS!!!!!!
Sep 10, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer not able to hook up to new Dell
your printer the g85 on the backyou will see below yhr bar codes where the power cord is four connections. looking at it from the back facing you on the far right is the power cord next to the power cord is the cord from the top lid second from the left i dont use this but i think it is the serial connection and far left connection is the usb cable the usb is the best on to use the two phone lines on what i call the leg or base far left remmber they need a special phone cord most cords only have two wires hooked up this on needs all four or it just want work right.hoop this helps
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Hi, My family recently purchased a Brother MFC-210 and brought it home thinking you could hook it up with a USB cord. To our surprisement, no USB slot was on the printer and could only be hooked up with a...
You need to use a category 5 Ethernet cable, not a standard phone cord. A Cat5 cable has 8 wires, where a phone cord only has 4. Surprising that you got anything to print. Look at the connector to verify that it has 8 connecting pins. It is also wider than a phone connector plug. You need to plug the printer into a Ethernet Hub or Switch which in turn connects to your ethernet (network) card or port on the computer. It will most likely not work if you plug it directly into your computer.
Mar 18, 2008 | Computers & Internet
IP1500 won't power on
is the usb cord plugged in properly, try reconnecting the data ribbon from the print heads to the printer. hope this helps
Sep 05, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Sony UP DR100 Thermal Photo Printer Logo
53 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
