Question about Baby Gear
Jardine convertible crib instructions
I have a Jardine convertible crib model 0308L00 and misplced the manual. I would like to convert it to a day bed but can't. I can't even find a website for Jardine Enterprises. Can you give me any suggestions w/o writing a letter to the company with my request?
Thanks,
Bkcnyy
  • 2 more comments
  • Anonymous Aug 01, 2008
    I bought a floor model jardine crib from babies r us and I don't think they gave me all the parts. The sliding side falls off the crib. I can't find instuction manual or a website either
  • jenak2776 Aug 03, 2008
    I also have a Jardine convertable crib and cannot find the instructions. I would really like to change it into a toddler bed but am not sure how.
  • aswise76 Dec 04, 2008
    Has anyone converted their Madison crib to a full size bed yet? I ordered the conversion rails from Babies R Us and they fit, but there is a gap between the end of the mattress and the foot board - seems as though the conversion rails are too long for the full size mattress - I dont know what to do - I have a call into Jardine who asked me to send pics and an explanation to see what can be done...Im just afraid to put my son it, because if he slides down to the end he can become caught between mattress and footboard...any help would be appreciated!
  • Anonymous May 17, 2009
    I have a 0303B00 model convertible crib by Jardine. I lost the directions to convert to day bed. Can anyone help with the instructions.
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Posted on Sep 24, 2008
Http://www.jdservice.biz/Instructions Just for anyone that is looking for information on instructions manuals for Jardine - this is the best site to find them. Hope this helps!
Posted on Oct 31, 2011
I came up with a way to fix the problem. I bought a single bedrail for the crib and used that. Here's how I made it work. I raised the bed up from the bottom level to the one just above that and that I put on the wooden guard rail piece that came with the bed as instructed. Then I just put together the bed rail that I purchased and laid it on inside the metal frame. now normally because they're made for actual beds and non crib day beds there are 2 plastic joints that would hang over...but I just made sure that they were sitting on the inside of the metel frame. then I secured the bed rail with the straps that came with the rail and laid the mattress over top of it. For me it's worked well. My daughter is almost two and a half and so far has understood that the rail isn't a toy and not to play with it so, so far so good. The reason you raise up the metal frame one level is that without it the plastic joints on the bed rail would not have room between the mattress and the wooden guard rail. and the guard rail still protects and stablizes the metal frame and bed at that level.
Posted on Aug 31, 2008
For those that feel uncomfortable with the height of the guard rail isn't high enough to keep your toddler from falling out of bed, here's a suggestion for what we did to make it work so we could use a safety rail that we purchased from K-Mart. Make sure the guard rail is positioned so that the "lip" part is facing the ground (instead of up, which makes it come up just barely above the height of the mattress). Then, move the entire rail down so that instead of putting both sets of screws in on either side, you're only putting in the bottom screws but you're positioning them in the "top" hole on either side (again, with the "lip" portion pointing downward). This makes the guard rail flush with the bottom of the mattress/spring set, and allows you to put a standard safety rail under the crib mattress. Yes, the lower half of the guard rail is not securely screwed into place, but with the one set of screws, it's enough to secure the toddler bedframe. And yes, most safety rails you buy for regular beds say not for use on toddler beds, but we used it with my daughter for about a year with no issues. Here's the only pic I found that kinda shows what it looked like. You can see the bed in the far right side of the pic (http://www.babyhomepages.net/picture/?pid=118029&currentalbum=)
After converting it back to a crib when my son was born almost 2 yrs ago, we have recently converted it back to a toddler bed, and this time we're using it with the guard rails installed correctly, with no problems with my son falling out of bed! Currently, I'm looking at finding the conversion rail set to convert the thing to a full bed, as now our son & daughter have decided that they want to sleep together in the same bed!! So now I've moved on to another problem....tracking down that elusive conversion rail kit! Ha!!
Posted on Oct 30, 2008
Thats so weird, I have this crib too. Did you see that Jardine has a recall on a bunch of cribs. This one is not included, but I swear it should be. My daughter has kicked the rail before and it sounded like it was cracked. Also, there is no rail included for the toddler bed, so..... be prepared for a lot of sleepless nights if your child resists and also falls out of the bed a lot. I have had to sleep on the hardwood floor in her room so that I am there in case she falls out of the bed. I put down a bunch of pillows and blankets that are almost as high as the bed itself. LOL! Can't buy a bed rail for this crib :(
Posted on Aug 04, 2008
I just found the instructions/manual/packet for our Madison Jardine crib. My husband is reading them as we speak. If you want them faxed to you, you can email me at kimcramer22@aol.com. This shouldn't be so difficult!
Posted on Aug 03, 2008
How do you convert the Jardine crib, model # DA715BC, into a day bed for toddlers?
http://www.jdservice.biz/JDBusinessFiles/ProductDocuments/DA715BC(GRW).pdf
Hello! This is Products America! We are the crib hardware specialist! This is the direct link to the Jardine Crib Instructions that include the instructions for converting your bed into a toddler bed. I hope this helps!
Sep 25, 2010 | Baby Gear
Instructions for converting Jardine crib to day bed model 0308C00
This crib is on the recall list, depending on the date of manufacturing. PLEASE check this out! We have the same crib and I just found this out today. see http://www.jardinecribrecall.com.
Aug 16, 2009 | Baby Gear
Need to know how to convert from crib to toddler bed
Unfortunately Products America does not provide parts to the Jardine cribs due to a recent recall they underwent that covered a large quantity of their cribs. I did check your model number and it IS on the recall list as one of the cribs that has been determined unsafe. You may want to check on that before continuing use of the crib, even in toddler bed form it may be unsafe. Here is the link to the Jardine recall page: http://www.jardinecribrecall.com/
Jul 31, 2009 | Baby Gear
Jardine Black Olympia lifetime convertible crib
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
Apr 03, 2009 | Baby Gear
Instructions for Jardine Crib
You should look on the website because I think that this crib has been recalled.
Mar 31, 2009 | Baby Gear
Converting crib to full size bed
This crib (which I also own) has been recalled by the manufacturer. I just found this out today. If you follow the link below, you can submit your information online to get a recall kit sent to you and to receive a voucher to get a new crib. My son is almost ready for a bed, but I figure I could use the voucher to purchase a new crib that comes with the conversion rails to make it a full-sized bed. Hope this helps!
http://growingyourbaby.com/2008/06/24/jardine-cribs-sold-by-babiesrus-due-to-entrapment-and-strangulation-hazard/
Mar 18, 2009 | Baby Gear
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at gistecknician@aol.com.
Feb 21, 2009 | Baby Gear
I just converted my daughters crib this morning. Here is the scanned in instructions for model 0308L00...
http://www.quickfilepost.com/download.do?get=a2c386481631b2b6535ac1dd95a70b9b
Sep 23, 2008 | Baby Gear
Baby Gear Logo
9,200 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
