Question about Amana Heating & Cooling
How long does it take to put a little R22 Freon in an Amana Central air unit
The manufacturers want you to let the system run for 10 to 15 minutes for the system to stabilize before adding freon. Then after adding it needs to balance out to check either superheat or the subcooling. Depends upon the metering device of the evaporator coil.
Posted on Jun 11, 2008
What kind of freon was used in this unit when made
You didn't give a model or brand so here is what to check. Find the model--serial tag on the air conditioner and it should tell you type of freon and usually the amount. Most older air conditioners were freon R22.
May 20, 2015 | Heating & Cooling
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
Aug 18, 2012 | Haier Heating & Cooling
I have a goodman Model CKL 36-1K . It says Factory Charge oz R22 . Does that mean it uses R22 freon? The guy who sold it to me says it uses 410a and was only 2 or 3 years old. The serial # is 040637071 ....
Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
Jul 06, 2012 | Goodman CKL36AR36 Air Conditioner
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
I have a Nordyne unit I need to locate where the freon is put in the air conditioning central air unit
The refrigerant is charged into the system on the low side or the larger line outside at the condensor. Unless you have an EPA card to buy R22 you have to have a service tech Mainly for your safety. Get a free estimate wont cost you anything and you know upfront what it will cost. Rus
Jul 04, 2009 | Whirlwind FH-778 Air Conditioner
How do i charge a AMANA Ptac with R22 freon
Also, if you get caught working on ANY freon based refrigeration without a license, you could face a large fine. Freon isn't $3 per pound anymore, it's quite expensive and you don't want any of it wasted. Have a licensed technician do the work. He will know exactly how much refrigerant your system needs, and he can remove what's there and add to it.
Jul 02, 2009 | GE Zoneline AZ55H07D Air Conditioner
Can I switch R22 for 34A in my central air unit
hi.no you cant.the system is only desinged for the r22.
Jun 09, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
123 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
