Question about Maytag SDE3606A Electric Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
TIMER DOES NOT MOVE, DRYER WILL START BUT WILL NOT SHUT OFF
WE HAD A REPAIR MAN HERE BUT DRYER IS STILL DOING THE SAME THING
  • indy 66 Jun 12, 2008
    The repair man was suppost to change the time but I do not know if he did, I was not at home.]
  • bpeagle1 May 11, 2010
    Did the repairman replace any parts like the timer or timer motor?
  • 3 Answers
If the repair man left a service call report it should be listed on it.
If you turn on the dryer and manually move the timer through a cycle will it shut off when moved to the end of cycle?
Posted on Jun 12, 2008
  • 254 Answers
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
  • Most reparable companies will offer a warranty on service if the timer won't advance still and your invoice shows it was replaced i'd call your tech back.
My Maytag Atlantis Intellidry Dryer won't start unless I move it around
If you have to move the whole machine then I would say you have a bad wire somewhere. If you have to move the timer around then you have a bad timer.
Dec 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Maytag SDE4606AYW electric dryer won't start. After drying several loads successfully, I set the timer knob, there was a humming noise and the dryer won't start. The humming noise happens at any timer...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
dghj53
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Oct 25, 2007 | Dryers
Maytag SDE3606A Electric Dryer Logo
376 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
