Question about Singer 7436 - INGENUITY
7436 beeps problem
When I press pedal I can hear 3 beeps, but nothing happen. Mechanicaly works, when turn wheel, lights are on.
  • 323 Answers
Raise your button hole lever which is near the presser foot.
sewman7
Posted on Jun 19, 2008
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
My buttonhole is not working I hear a beep when i press down on the foot to go, what am I doing wrong
I get the same beeping when I forget to pull down the buttonhole lever
if you have the automatic buttonhole & the buttonhole foot that you have to put a button in,,check & see if there is a buttonhole lever that has to be pulled down, it will be a lever to the left of the needle bar
Aug 07, 2011 | Singer 7436 - INGENUITY
The hand wheel & the overlock machine 14SH654 cannot move
so nothing is moving at all either by pressing the pedal or turning the hand wheel? Can you hear the engine humming or is the light working okay?
If yes, then this could be a gear failure inside the machine and not something easily fixed. Is this a oldish machine that has either had a lot of work or been sitting for a while? Has it been serviced at all in the past?
My Bernina 334D failed and it was a nylon gear in the main drive area which I had replaced but the dealer wasn't keen to do it, they wanted to sell me a new one. However, I checked with Bernina themselves that the part was available and how much, then talked to a local repair guy and he did the job for me. About 1/3 the cost of a new one though.
I'd suggest you take it to a Singer dealer and ask for a quote and find out if this is what has happened to your machine.
Mar 19, 2011 | Singer 14SH654
White w2500 serger - nothing happens when foot pedal pressed
Sounds like it could be wiring - probably a job for a mechanic
Aug 26, 2009 | Sewing Machines
Power is on, but it won't work at all.
Try pushing the bobbin winder to the left. if that doesn't solve it and it still makes a whirring noise the belt is probably off the handwheel and will need to be seen by a technician.
sewman7
Oct 27, 2008 | Singer 7436 - INGENUITY
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Singer 7436
I BOUGTH A USED SINGER MACHINE MODEL #1036, 'creative touch, the machine came with not assesoris or manual. did you can help me to find literature related with this products
thanks
Dec 28, 2007 | Sewing Machines
Singer 7436 - INGENUITY Logo
221 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
