Question about Refrigerators
Water won't dispense from side by side fridge
I received delivery of new Kenmore Side by Side refrigerator today. My husband installed ice maker kit. The ice maker has already begun making ice, however the water dispenser will not dispense water. There is water coming through tubing and into filter. Please advise as to what problem could be.
    Problem Solver:
  • 5 Answers
Check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Posted on Sep 22, 2009
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Water is leaking from the Ice maker on top of the
the water valve on the back of the fridge has malfunctioned.
Jul 21, 2010 | Kenmore 57029 Side by Side Refrigerator
New fridge wont dispense ice?
the ice maker has to reach 30 degrees for it to start working feell inside the icemaker to make sure your getting water
Apr 29, 2010 | LG LRSC-26922 Side by Side Refrigerator
Ice maker not making ice
I don't recommend repair on this unit. Simple replacement. Try to find Ice maker kit @ local home depot or lowes that is same. You can buy whole kit for $50-$75.00.
Aug 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
I can get water to the water dispenser in my side by side. but it will not make water. It's a Kenmore 22 side by side. I believe the model number is 9522611. We switched the wires on the solenoid and it...
the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
Jan 15, 2018 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Kenmore Elite Fregirator
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
