Question about Frigidaire GLTF1670A Front Load Washer
Runs through the all cycles in 5 minutes!
My washer will go through every cycle from start to finish in 5 minutes or less. Any ideas??
  • Anonymous Jun 29, 2008
    I'm having the same problem, all cycles in about 5 minutes and tub never turns!! I checked the belt and it's ok.
  • 4 Answers
Only the timer controls time, so it needs to be replaced. But usually they STOP turning. I've never heard of one going into fast forward.
Posted on Jul 14, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Calypso won't finish spin cycle
Error is Insufficient cycle!
first try to unplug the appliance for 5 minutes and then restart it and see if the system reset!
if not you need hands on service. Not every situation is easy.
Please let me know what happened?
Plese rate me at our site too, before you sign off!
Thank You for using our service!
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
FRont loader washer
try this,on next load use NO deteregent/soap.Please leave a rating.
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Display Lights Flashing
try to unplug the power cord for more than a minute to see if the control panel reset itself first
May 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
