Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Bad capacitors I have the blue flickering screen problem with my wd52525. I disassembled the electrical chassis and found 4 bad capacitors. I have ordered enough to replace all of the potential trouble capacitors because I don't want to have to do this again. After I replace the capacitors I will try to reassemble the tv but to tell the truth, I'm not real confident, lol. Is there a detailed description for putting this thing back together? If not, it may end up in the landfill!!! jeh
  • Mitsubishi Master
  • 8,617 Answers
Go to the link below, they have the factory manual with fetailed photos of the disassembly and reassembly of your unit.
http://servicemanuals.vstore.ca/
Posted on Jun 14, 2008
2 Suggested Answers
  • 16 Answers
SOURCE: Bad Mits capacitors
if your going thru all this trouble, be sure to check the 4 capacitors on the DM board (1000mf/16volt), the 4 caps on the formatter board (1000MF/16volt) and the 2 caps on the power supply board (3300mf/10 volt) Mitsu recoomends changing the 1000mf caps to 680MF/16volt.
It is kind of a pain to change these.
good luck
Posted on Jun 12, 2008
LT-46133 FLICKERING BLUE LIGHT
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Mitsubishi LT-46133 46 in. HDTV-Ready LCD...
Our Panasonic rear projection TV (model #: PT51G42V) started having problems today. It appears you are looking at the screen through a lens of some sort, as it is rounded and the top of the picture is cut...
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Televison & Video
Goodafternoon, power comes on with blue light showing then a quick two flicker of the screen then black...electrolytic co-passers?bad?
First you need to understand that there is a problem inside the unit that is why you got the flicker and the black screen. Most likely causes are a bad lamp, bad t-com board or a bad capacitor inside the unit.
Either ways, have the television unplugged, assess the main panel for any bad capacitors, if any found, then replace it with a new one, if you do not find any faulty capacitor, then assess the lamp to see if it is faulty, if it is, then you have to replace it, if the lamp does not seem faulty, then you will have to check the t-com board and replace it if it happens to be the faulty component.
To know if a capacitor or a lamp is bad, all you have to look out for is if the capacitor is swollen or looking burnt, and for the lamp all you have to look out for is if it has a leak or is broken or looks burnt.
Take care and good luck
Dec 03, 2010 | Polaroid 3211TLXB 32 in. LCD Television
Blue light on/off switch to monitor flickers, but will not turn o
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors2.gif parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 10, 2009 | E-Machines eMachines Monitor E15T4
Mitsubishi wd52525 capacitors
well capacitors are located on the chassis but only the high voltage capacitor can cause electric shock,dont be afraid,u can discharge the current on it.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 55 inch 1080 tv
Is it flashing a two digit code such as 34 as thats a common fault with the WD52525 V26 chassis for a lamp abnormality caused by two bad capacitors on the PWB PCB
Jun 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bad Mits capacitors
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
AV-60D501
There is a 5, 9 & 12 volt dc regulator on the chassis that could be causing this. Three legged transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad and a 35ufd @ 50v capacitor near it is bad. From the tuner as ground check the third leg on the regulator for less than 9v dc.
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
