Question about Toshiba 36A42 36" TV
TV won't recieve signal from remote
The remote is working, I tried it on another toshiba, but this one is not getting any signal. Any ideas?
  • Johnston-cab May 06, 2009
    Tv does not receive signal from remote all of the time,It works intermitantly .Remote works .
Did u try the sliding button on the left hand side, make sure its slid up to the top, on tv, thats what i did when that happend to me
Posted on Feb 01, 2009
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
Hi I have a Aldi bauhn LCD tv and its not recieving the remote signal. I have checked through a camera for the remote control light signal and it works with every button. So that leaves the reciever
Will cost more to fix then a new unit , replace it and try to buy a extended warranty with the new one, most times you can get 3 years after the original warranty runs out.
Apr 04, 2017 | Televison & Video
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote...
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Jun 02, 2010 | Toshiba 32AV600E 32 in. TV
The t.v. does not have a picture or no sound but the dvd works?
U have the original remote?Tries pressing any of these buttons.Said Input,Function or AV buttons.U will get Tv,Video 1,2 or Input 1,2.Continueously pressing the button to go out to the display said TV lable will get tv signal.U have cable right?No,cable or satalite these day will not get a tv signal for an Analog tvs.It all digital,have analog tv to recieve free air tv must have a Digital Converter box for analog tv.
Mar 24, 2010 | Televison & Video
The hand held remote will not work for my toshiba tv (model #cz32v51). I put fresh batteries in and that did not help. Bought a universal remote and that did not work. There must be a remote receiver...
its batter in a shop were spares can be found. in side a tv there is a photo senser which converts light into electrical signals.
let the photo diode be tested
and also the remote you have on other toshiba sets to confirm, if remotes are a problem or not.
remotes have codes to change to another remote, 060, 019, 014, 052, 059, 075.
Apr 01, 2009 | Toshiba CZ32V51 32" TV
Remote doesn't work
here's a tip to test all remotes
point it at your digital camera/webcam
although the human eye cannot see infared, your camera lense can
watch the monitor to check if its flashing.
also - if you have moved the set, perhaps something inside - such as a wire loom - has fallen in front of the infa red reciever? or it may just need the window cleaning
Nov 22, 2008 | Toshiba CZ32V51 32" TV
Installed tv ..trying to set up remote control
Remote codes
http://www.remotecentral.com/index.html
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 61HX70 61" Rear Projection...
Remote will not control TV (but will control other devices)
Your remote control could still be the problem. Try another Toshiba remote on your TV or try your remote on another Toshiba and see what happens. Don't ever look past the easy repairs.
Mar 16, 2007 | Toshiba 36AF53 36" TV
Toshiba 36A42 36" TV Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
