Question about HP Compaq Presario V2000 Notebook
Adding memory how do i change the memory card on my compaq presario
    Genius:
  • 1,601 Answers
Posted on Jun 11, 2008
What is the video memory of a Compaq Presario SR5712F PC Desktop
Description---- Problems with video cards show up as intermittent system lockups when playing 3D games, small dots of color spattered across the Window desktop, the inability to run certain 3D games, and the inability to open Windows normally. All of these issues can occur because of video hardware or driver problems. Find an item below that matches your video need: For integrated video memory that is adjustable, use the following steps to change the amount of video memory (RAM) from the PC BIOS Setup:
  1. Turn on the PC.
  2. When the blue HP screen appears, press the F1 key. Entering Setup should appear on the screen.
  3. When BIOS Setup screen appears, use the RIGHT ARROW key to select the Advanced screen.
  4. Use the down Arrow key to select the video memory setting; for example; VGA RAM Size, integrated video, or On-Board Video Memory.
  5. Press the Enter key.
  6. Use the down Arrow key to select the desired amount of memory or memory setting that is listed and then press the Enter key. CAUTION: Do not select a DISABLED setting without a video card installed! Doing so can cause the monitor to go black until a video card is added or the BIOS is reset.
  7. Press the F10 key, and then press Enter to save changes and exit. The PC is set to use the new video memory setting.
tell me if this was helpful
Apr 26, 2010 | Compaq Presario SR5712F PC Desktop
I am thinking of adding memory to my Compaq Presario SR111ONX. I was looking for a schematic of the motherboard or a diagram showing the memory slots and how to add it.
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Sep 19, 2008 | Compaq Computers & Internet
Do all compaq presario cq60 have a memory slot?
It has a memory card slot (left-side towards the front), but your particular memory card might be too big for the slot. There are several different variations of memory cards out now. Of course the newer the variation, the smaller that card is. This laptop is fairly new so it might not be compatible with your memory card. Does your camera have a USB cable for transferring pictures? If so, then just use that.
Mar 13, 2010 | Compaq Presario CQ60-220US PC Laptop
HP Compaq Presario SR2150NX PC New Memory not recognized
Remove the Old memory and see if the system reconizes it, if yes the old is not compatable together.
If no the new memory is not compatable with your system.
Aug 29, 2009 | HP Compaq Presario SR2150NX PC Desktop
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
Compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
The monitor reads: system boot failure. Insert recovery disk.
McAffee Security or adding memory cards should not effect the ability to do a system recovery, but so be it. Here is a list of presario laptops, do you know which is yours?
s.gif s.gif s.gif » Compaq Presario 12XL325 Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ20-325TU Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ45-325TX Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ40-325AX Notebook PC
» Compaq Presario CQ40-325LA Notebook PC
» Compaq Presario CQ40-325TU Notebook PC
If so, click on it and you will find the recovery disks.
Mar 18, 2009 | Microsoft Compaq Presario C501nr Notebook
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
Added memory but one memory card (Original) not recognised
OK, according to Crucial.com your RAM does need to be installed in matched pairs.
Here is a link for your computer information:
http://www.crucial.com/store/listparts.aspx?model=Presario%20SR1460AN
If you get another 512MB module and install both pair, it should work well.
Jan 13, 2009 | Compaq Computers & Internet
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
HP Compaq Presario V2000 Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
