1992 Oldsmobile Eighty Eight Logo
Anonymous Posted on Oct 30, 2010
I have a 1992 olds 88 runs fine when its cold but when it gets warm it wants to run bad back firing missing ben working on it for weeks replaced mass airflow tps and air sensors also notice that radiator fan runs all the time and sometime my heater blower comes on when it wants to last but not least when open car door interior lights come on and stay on olny way to get them off is disconnect battery when reconnect they stay off until you open door. thank you dale diemer
  • ak501 Oct 30, 2010
    Do it backfire out the exhaust or through the intake?
  • Anonymous Oct 30, 2010
    through the intake
Anonymous
Level 3:
  • Oldsmobile Master 3,640 Answers
  • Posted on Oct 30, 2010
Anonymous
Oldsmobile Master
Level 3:
Answers
3640
Questions
6
Helped
1674530
Points
10518
Replace coolant temperature sensor and go from there!! here are a few causes for engine back fires--common causes are==lean misfire due to low fuel pressure or restricted injectors. breakdown of secondary including internal ignition, coil arching and a dead spot in throttle position sensor. it is hard to say with out being there!! but my first guess would be to check out tps first. then go from there. have a good day!!
    thank you will check out and tell what worked
On my 88 Lincon Mark 5 when it is cold it will start but it misses after it starts to warm up it shuts off and has difficulty starting back everytime we go to put it in gear it will die it wont even...
Sounds like you have a bad ign. module. When the engine is cold moisture causes the miss and when the engine warms the module shorts out all together.
Cant get my 1992 GMC to fire
replace the ignition module or pickup coil located under the distributor cap ignition modules work when cold and will stop firing when they are warm when they r going bad
2helpful
I have a1992 olds 88 that is running ok when cold. when it warms up it misses and has no power . sometimes it stalls at corners. the mas air flow ,and computor have been changed code 41 and 44 shoe up on...
when's the last time you did a full tune up? (air and fuel filter,plugs,wires, cap, rotor) or could be a number of things. i would look at the temp sensor. i believe when they fail, they peg out all the way cold or all the way hot. so your car thinks it is still cold, when you have reached operating temps, causeing your misfire. good-day !
Every time I start my truck it misfires very badly. I actually gotta hold the pedal down pretty far to make it stay running. But once it warms up, it's fine but sometimes has a slight miss while driving...
idle air control valve does your vehicle have one check to see if your geting the correct amount of fuel at rail sounds like a fuel issue cloged injector
3helpful
2answers
1992 olds 88 stalls. after it sits for a half
Is the Service Engine Soon (or Check Engine) light illuminated on the instrument panel? If so, then have someone pull the codes and post them back here. Autozone will do this for you at no cost.Caution: don't purchase any parts after reading the codes on their recommendation! If no codes, then suspect either a bad crankshaft sensor or camshaft sensor. There are other possibilities too, but these are primary. I have seen MANY bad crank sensors do exactly what your describe without setting a code.
1992 Dodge D-150 318 Magnum runs erratically, stalls til warm...
Replace the acceleration pump. It's a small diaphragm on the carburator, near the fuel line. Usually less than $10.
2answers
2000 silverado 4.8 v8 runs bad when it is cold out side.
Try replacing the coolant temperature sensor for the injection system.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
