Question about Denon AVR-4806 Receiver
Denon AVR-4806 I work for RAC natnl. Product Service and my receiver has static in all channels and will flair up and put the unit into shutdown. I can scope the input caps at all the volume control IC's and the signal is clear from like the tuner but at the output of the volume controller IC's, you can see the static and flairing up. Seems to be all channels. Is there a fix or do I need to persue a new Audio Unit board? Is one available?
  • 4,234 Answers
The most likely cause of this is a failing transistor or two in the pre-amp section. There should be a pair of transistors in what is caled a dif-amp setup. These are the most likely candidates for replacement. They may be in a single 5 pin package. If you can, try hitting some of the transistors with freeze spray when the problem occurs. If the problem goes away, the last part hit with the spray is the likely faulty component.
Dan
Posted on Jun 11, 2008
Denon 4806
If the channel is blown and you have replaced the fuse your receiver needs a trip to the repair shop.
Aug 24, 2014 | Denon AVR-4800 Receiver
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Only left channel working on avr 1912
Sounds like a possible amp problem. Probably needs to go in for repairs.
Jan 07, 2013 | Denon Avr-1912 Home Theater Av Receiver...
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
I have an AVR 4806 I have a powered sub plugged into the SW but no sound coming out of the sub. The other speakers are working but just not the sub. Is there a setting that I am not seeing?
is it plugged into the sub-in or sub-out. if all else fails just plugg your sub into the audio out somewhere on the bk and youll be fine.
Jan 31, 2011 | Denon AVR-4806 Receiver
My Denon AVR 2805,has a problem. In a few seconds after switching on, it automatically turns itself off. What is the cause of this problem? How can I fix it?
This unit is in what is termed :protect mode". This means that one or more of the amplifier channels has a rpoblem that was detected by the protection circuit inside and the unit has been shutdown to prevent further damage. This is often shorted output transistors or a defective amp pac for the surround channels. Expect a parts cost in the $50 range for this repair.
Dan
Oct 08, 2009 | Denon AVR-2805 Receiver
How do i reset my denon avr 4802
Switch off the unit and remove the AC cord from the wall
outlet.
Press and hold the DIRECT buttons and STEREO buttons, and
at the same time, plug in the AC cord.
Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
That will default the unit
Jul 08, 2009 | Denon AVR-4806 Receiver
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Dan
Apr 05, 2008 | Denon AVR-3805 Receiver
Denon AVR-4806 Receiver Logo
163 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
