Question about Samsung Digimax S500 Digital Camera
Work issues my camera makes 3 beeps then shuts off !!!!!! I tryed to use gentle pressure with the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. it still wont work!!!!!!!!! AHHHHHH SAVE MEEE!!!!!!
  • 579 Answers
Jammed or off the track, try rotating the lens if it rotates out, maybe the middle coller part, or take it apart and see if you can see the fault. No other options, sorry. SO many lens problems with this design, too bad.
Posted on Jun 11, 2008
My pandigital ereader won't connect to wifi all of the sudden. I've tried everything. The manual said to reset, and now it's dead. Can't get it to turn on. Any suggestions?
I rare case,the wifi module can disconnect for it socket.
It's usually cause by mishandling the unit.
If it's under warranty then you should send it in for repair.
====== The DIY method is to power off the unit.
Place a large soft towel on a table.
Place the display face down.
Apply GENTLY pressure (side to side and top to bottom) on the back of the unit.
PLEASE apply pressure gently!!!!!!!!!
With some luck,you will press the wifi card back into its socket.
Sep 11, 2011 | PANDIGITAL 7270FW Tablet
Tip
Beeps 3 times; shuts down;lens won't retract
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
on Jun 28, 2008 | Polaroid i531 Digital Camera
I have a zoom error. When I turn on camera it just opens and shuts. What should I do?
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | FUJIFILM FinePix J40 Digital Camera
I have a canon powershot SD13001S and whenever i turn it on it says lens error how do i get it to work?
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed air into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting. 2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera OFF and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Aug 29, 2010 | Cameras
The vision is blury and it keeps flashing E:61:10
E:61:10 is a lens error code. Could be a connection issue between the lens and the main board or a bad lens. You will need to have this looked at by an experienced technician. www.austintelstarservices.com
Aug 29, 2010 | Sony DCR-SR47 Camcorder
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
My lens won't retract or open and beeps 3 times and shuts off
May 15, 2008 | Polaroid i531 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
57 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
