FixYa.com
Tags:
Garmin StreetPilot c340 GPS Receiver
C340 Garmin GPS
posted by broken gps on Jun 11, 2008
When I turn it on it lights up and then turns itself off and will not let me turn it on for 5 minutes and then it turns itself off immediately again.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 22, 2008
Not Rated (0)
ferret08
Rank:Apprentice Apprentice
Rating: 95%, 3 votes
Besides resetting my unit I needed to replace the fuse in the car adapter.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 18, 2008
Not Rated (0)
ronbot
Rank:Wiz Wiz
Rating: 88%, 18 votes
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Can you Help with these GPS Devices problems?
cannot download from the disc...
cannot download from disc to my... Answer This...
GARMIN C340 VOLUME CONTROL
hi there     the... Answer This...
Incompatible audio version
Hello. I updated my StreetPilot... Answer This...
sp340
Unit will not power up. Checked... Answer This...
screen message
when I turn it on it says I... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
