Question about Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range
Over weak? after working well, suddenly, very low heat, smell some gas, not really firing up
  • 413 Answers
The igniter can actually warm the oven to over 100 degrees. In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on or keep the the gas valve on. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on Jun 13, 2008
I smell gas
Sound like it could be quite a few things. Off the top of my head I would check that the car is firing on all cylinders. If one has gone down you will have fuel travelling along the exhaust pipe, which could explain the smell. If you have lost a cylinder it will be as rough as a badgers B*M, and you will get rubbish mpg. Check if you can smell fuel from the exhaust pipe (Not while the car is running I don't want you to get carbon monoxide poisoning), just give it a quick start and a few revs first. If it is or anyway If you take the plugs out one at a time look at them to see if they are wet and smell of fuel, (After a quick start and a rev). Check your air filter as well you could even take it out and see how it runs (Not for long just a quick blast) see how you go with that.
Good Luck
Mar 15, 2014 | Cars & Trucks
Oven igniter works but oven doesnt lite. Strong smell of gas also. Stovetop works fine. Whats wrong!!!?
replace the ignitor,even though trhe ignitor glows orange its getting weak and cant pas enough current to open the gas valve to supply enough gas to fire the venturi tube,so it supplies gas but wont ignite this is where your odor is coming from
Jan 06, 2013 | Ovens
I have a 1999 oldsmobile alero ... i'm smelling gas fumes as the car sits w a/c or heat on ..gas needle dosent work properly.. and humming noise...seems to smell strongest when low on gas..went t
For the first problem, if you can get me the codes I may be able to help you figure out the problem with the gas smell. The fuel gauge problem could be the gauge on the dash or the sending unit in the tank.
You should have the body computer scanned for trouble codes to find out whats going on with the ABS and traction control.
I have no clue on the humming noise.
Aug 09, 2012 | 1999 Oldsmobile Alero
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Jun 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kenmore 95680 / 95681 / 95682 / 95684 Electric Kitchen Range Logo
83 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
