Question about Gateway 310S (2900621) PC Desktop
Blank monitor Loaded driver for new HP printer. When computer was restarted, the monitor was blank. HP can do nothing to help because all help needs a monitor. I tried a spare monitor I have and it is blank also. I am using my laptop to seek help.
  • 2,794 Answers
Try this.
Turn the computer off.
Press F8 on the keyboard and select safe mode.
See if the monitor is corrected with that process and restart windows in the normal mode.
Posted on Jun 11, 2008
Installing a new blank hard drive in a DesignJet
The hard drive is the formatter in the T610.
HP has a special operating system software loaded on the hard drive, so you can't just format a blank one and install it.
The whole formatter assembly will need to be replaced.
Mar 15, 2014 | HP Designjet T610 InkJet Printer
Printer prints blank page
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Screeen went blank after changing resolution and hz appeared
refresh set to high boot safe mode change settings.
this has worked for me and XP.
Don
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Printer copies come out blank
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP Officejet 7130 All-In-One InkJet...
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HELP! HP 2550L printer needs installed with NO CD!
You need to download and install the drivers and software of the printer. They can be downloaded here from HP. Just pick your operating system.
Jan 27, 2008 | HP LaserJet 2550L Printer
Printing problem
Check it's not a software driver fault, uninstall both printers drivers from pc and disconnect the printers and restart. Re-install the driver and then connect the printer when prompted
Jan 07, 2007 | HP Pavilion a1210n (ED895AA) PC Desktop
Gateway 310S (2900621) PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
