Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Frigidaire Stacked Washer and Dryer
I think the draining system of the washer is clogged. For some reason, the washer will not completely drain. So, the laundry does not wash and is not wringed well. Is there a filter that we can clean?
  • blkmtn Jul 18, 2008
    Spins but does not complettely drain.
  • 95 Answers
Check to see that the agitator is spinning out the water, if it is not, you may have torn the wire out of the door switch, which will prevent total water discharge
Posted on Jun 25, 2008
My frigidaire washer does not drain
Good Afternoon Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831CS, is not draining. First, check the drain hose for any kinks or clogs inside of it. Secondly, make sure that the drain pipe is not clogged. Finally, reset your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer does not drain, how do i fix it?
Good Morning Friend,
I see that your Frigidaire washer, model# FEX831CS, is not draining. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still having trouble with your washer draining, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why your appliance will not drain. Hope this is helpful.
    -Best regards-
    WP
May 14, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer Leaking
I would check the drain pipe for clogs. if that doesn't work then it is probably the drain in the washer. I have had the same problem with my washer before and it was fairly new. mabe a year old
May 25, 2013 | Frigidaire FLEB8200DS Top Load Stacked...
My Frigidaire FEX831CS Top Load Stacked Washer / Dryer goes through the cycle till it gedts to drain, then nothing... pump out?
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer will not drain
I have the same problem. I changed the pump and the control switch, but it still does not drain the water out. I am about to give up. It sounds like we may have the same problem. I am still waiting to see if anyone knows whats wrong.
Jan 26, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
My washer will wash on all cycles, but will not drain it is a stackable unit
pump is clogged. slide out unit about 4 feet and tip back. you should be able to see pump to remove. Drain as much water you can before doing anything.
Oct 23, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Washer wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 02, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer not draining water
If the machine does not drain start checking the drain hose.
Ifthe drain lines are not clogged, then you will need to access to thedrain pump, and clean it , or replace it if it is not working.
Machine not draining can also be caused by a defective timer control, but this is rather unfrequent.
See also : It won't drain
This seller also have replacements and delivers worldwide.
Dec 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
159 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
