PROJECTION TV'S & DLP TV'S
A long time ago i had purchased a projection tv from sears. they suggested to get the "projection part" cleaned once a year. i just recently got a philips dlp and was wondering if the same applies to this tv. and then if so, who does it & where?
  • Anonymous Feb 25, 2009
    i have lost two bulbs in less than two years, at 250 a bulb I am selling my toshiba
  • 927 Answers
No, your DLP does not need the annual cleaning as your old projection tv did. The rear projection used high voltage, 35kv, which attracted dust and smog. I would recommend to have your DLP cleaned when your LAMP goes out. Your lamp should last 2-3 years, then I would call a factory authorized service dealer to replace your DLP's lamp and have them do the cleaning at that time. I do it everyday as a in-home service tech.I hope this help.
Posted on Jun 11, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
My Samsung DLP rear-projection TV has had a very dim picture for months. We have replaced the lamp once already.
How long ago was lamp replaced, also you can try cleaning dust off the lamp. Dust builds up on it and causes pre mature failure. Also moving the TV around can cause the bulb to fail after extended use. The bulb are only as good as any other regular bulb. They start taking longer to warm up then dont get as bright then fail totally. Some Tv's wont allow itself to turn on in some of those states.
Aug 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
"No Connection"... My first attempt with HDMI SUUUUCKS- HELP
The connector board inside the tv is the one has circuit traces already broken. there is nothing outside the tv can be done. The HDMI conector is high end technology solder. finally the solution is to replace the conector board inside the tv.
Jan 02, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
