Question about Konica Minolta Office Equipment & Supplies
Konica 7030 tray # 4 code
Looking for the technical manual that will tell me the machine code for the konica 7030's tray 4. I need to know waht the tray # 4 is coded in order to print directly from that paper tray from our IBM mainframe. I cannot print from the default tray 1 as tray 4 contains 11 x 17 paper which i need for a specific print job. thanx! vicki
  • Lockheed Jun 11, 2008
    Hello, thanx for trying. I already contacted the Vendor and am still waiting for a response. Was trying several avenues to get the info i need. You have a good day. thanx!
  • Konica Minolta Master
  • 2,794 Answers
You should contact Konica/Minolta for that information. That requires an tech engineer from K/M to fix that issue if it is possible to do or support.
Posted on Jun 11, 2008
My machine is not working with tray, it display jammed paper
machine tray will be clean .Printer fuser parts clean.plz tell me my cell no. 08273174139 vishal
Dec 07, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Nov 15, 2011 | Office Equipment & Supplies
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
Error code C-0211 Konica Minolta Bizhub C-351
It's called "Manual Bypass paper lifting failure". The manual says to check Tray 2 vertical transport motor. Check the wires to see if the are okay. Pull out tray 2, remove back cover, remove wire assembly from 4 wire saddles, remove 2 screws and the motor assembly. The should be 2 motors on the assembly and the one u need to look at is the bottom one. hope this helps.
May 22, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica 7030 copier/printer - service codes
Are you sure it's not 34-2.I don't see or know of a 32-4 in my service manual.If it's a 34-2 write back and I'll reset it for you.
Jul 24, 2008 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scanning with Konica 7030
A very general question. Have you triede looking in the manuals to see what is available?
You can find these documetns here:
http://help.bt.konicaminolta.ca/
Feb 06, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
128 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
