Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta Bizhub C450
Need to replace the transfer belt, cannot find the instructions on my user's guide. Do I need a repair tech or can I do it myself??
  • Sally25 Jun 12, 2008
    How do you scan multiple pages into one file? We do not have access to our manual at this time.
  • Anonymous Mar 12, 2014
    Control panel not working on Konica Bizhub C352. Have replaced imaging unit and transfer belt. Now the control panel not working. Can no longer fax and make multiple copies when you ask for one. Start buton does not work. Cannot dial a full fax number
HOW TO RESOLVE THIS PROBLEM
Posted on May 16, 2013
  • 167 Answers
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
Posted on Jun 12, 2008
How do I remove the transfer belt from c450 bizhub konica minolta
1st from the front Open the door and removed all Imaging unit start from the black. 2nd from the left side when your facesing the c450 Open remove the waste box. 3rd from there you will see the transfer belt on both side of it you will see screw just under the transfer belt loose it. Slide the transfer belt toward you.
Jan 08, 2015 | Konica Minolta bizhub C450P Laser Printer
Minolta C450 C-D212
Will require a re-flash of the board firmware, MFP. Multi-Function Board. Or Replacement $$$$$$$$$$$$$$$$$$$$$. Firmware via a Secure Konica Minolta Web site they like their firmware secure that is why you will need a tech.
Apr 28, 2014 | Konica Minolta bizhub C450P Laser Printer
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
Error p 5 konica milnolta bizhub c450
Remove the transfer belt. Then right below the fusing unit right where the edge of the transfer belt is located when normal installed right below where the edge of the belt would be. Are two sensors they are cover with the belt out and door open so you will have to GENTLE open them with your fingers and GENTLE clean them DO NOT USE AVACUUM CLEANER THE STATIC ELECTRICTY from the vacuum cleaner can destroy the sensors.
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
P 5 error in konica milolta c450
Sir/Mam
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed.. recommended a tech do this unless you known what you are doing.
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
Mar 29, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Nov 28, 2012 | Konica Minolta bizhub C450 Touch Panel...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
949 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
