Line across picture and then picture starts to shrink really small. I turn it off and turn it back on again. It last for awhile and then starts the same problem again
    Problem Solver:
  • 61 Answers
Possibly loose connection on the vertical ic it will be a ic with inline leads attached to a heat sink resolder these pins you should be ok
Posted on Jun 11, 2008
Glitchy picture with lines across screen when turned on
I can give you detailed guide describing exactly wich capacitors to replace . Your tv really only needs maybe 5 dollars worth of parts. But you must know how to solder and take things apart . also you must be able to put it back together. if only there was some way you could paypal 50 buck to me.;(
Oct 04, 2009 | Toshiba 50HX81 50" Rear Projection...
Lines across screen
Is your camera getting overheated in the sun?
Sep 08, 2009 | Samsung NV10 Digital Camera
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Panasonic 27
Initially I would suspect a problem in the Vertical section of the TV. This could either be the capacitor or the IC itself. In some instances, there are no component failures but rather cold solder joints.
Based on your post/description of :...Once in awhile picture returns to normal...", I am more inclined to think that it is a case of cold solder. which can easily be corrected by reapplying heat on the IC pins or the other associated/nearby components with the use of a soldering iron. Care must be exercised since TV units still pack high voltages even when off and unplug.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Televison & Video
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Picture reduced to a horizontal line across center
sounds like the vertical, more info
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
