Question about Singer 8280 Mechanical Sewing Machine
Cloth feeder does not work
I mistakenly changed some setting and th cloth feeder does not seem to work properly. The cloth does not move automatically. Any help will be very useful
    Genius:
  • 1,036 Answers
Make sure stitch length is set to longest possible - to start with.
This should be a series of dashed lines, or on a high number near the motor end of the machine.
There may be a small wheel or knob which can be in 2 positions - feed on or off. Make sure it is feed ON.
This is probably it.
Posted on Jun 11, 2008
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
Do I need to change the tension on my Janome 2049 sewing machine?
sounds like the foot tension needs to be adjusted.
Jul 08, 2015 | Janome Sewing Machines
Hai, perhaps you put the top and bobbin thread properly. Otherwise you heavy tight the tension . Please try to and adjust the normal tension and change the correct size new needle.
Mar 19, 2014 | Janome Sewing Machines
The cloth will not move
Have you adjusted the pressure of the presser foot yet? If you don't have enought pressure... it won't feed properly.
Here's a manual for you.... read through it carefully.
http://www.singerco.com/uploads/download/1070_white-1409-new-x.pdf
Dec 29, 2012 | White Sewing 1409 Mechanical Sewing...
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Sep 02, 2010 | Janome 4612 Sewing Machine
Cloth will not move forward
Cogs are feed dogs.
Check your manual to see if there is a pressure adjustment for the presser foot.
This may be a nob on top of the machine directly over the presser foot.
Turning the adjustment left/less or right/more pressure.
Also, refer to the manual for cleaning the bobbin and feed dog area as lint may be causing a bit of the problem.
May 01, 2010 | Elna 2005 Mechanical Sewing Machine
Cloth does not move . It sews when I pull the cloth myself, but it does not automatically moves the cloth by itself
Make sure your feed dogs are up. Feed dogs are moving metal parts in the needle plate that make the fabric move forward under the presser foot. Open up the shuttle box underneath the needle plate. There is a lever to the right of the the shuttle. Press the lever down and to the left to raise the feed dogs.
Apr 03, 2010 | Kenmore 15358
Have a Necchi 4595, need help
Increase the pressure on the presser bar. Usually this is located right above on the top of the machine.
May 18, 2009 | Necchi 4595 Mechanical Sewing Machine
While stitching interlock system is not working
Make sure the feed dogs are up properly. Under the arm of the machine, at the front, there is a dial. Turn it towards the picture showing jagged teeth as far as you can.
Mar 19, 2009 | Husqvarna Designer I
The fabric doesn't move forward.
What is the length set at?
Are the feed dogs visible at the needle plate?
What does the design look like in the pattern box?
Have you tried it on the straight stitch to see if is effected also?
Bonnie
Sep 21, 2008 | Kenmore 15516 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
