Question about Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 HDTV
The screen on my TV goes completely dark for about 1 or 2 seconds. Both the picture and audio go out. After 1 or 2 seconds, the picture and audio both come back and everything is fine. This will happen randomly and without predictability. Sometimes days will go by without incident. Other times it may happen several times a day. Can anyone help?
  • 3 more comments
  • nellynell Jul 28, 2008
    SAme problem 20-30 second shuts off then turnes on and it will do this all day...HELP{
  • will68_209 Sep 27, 2008
    Picture and audio go out, 10-20 seconds later come back. has repeated all day long. Any fix or smash it?????
  • bayoudj Sep 30, 2008
    Same problem as above. I will replace the lamp and see if that corrects the problem, but would like to know if anyone has found a different solution.
  • mmboliva Oct 03, 2008
    I now have the same issue. The tv sound and picture will go blank randomly. then reappear in a few seconds. Did replacing the bulb help?
  • Anonymous Mar 25, 2014
    when the picture goes out, if i turn the tv off then back on the picture comes back [only briefly at times but the left side is dark.
I purchased a new Lamp, but before I had time to install, the problem stopped occurring. I feel that this may be a lamp overheating problem due to dust or temperature and humidity within my house. I was going through power outages due to IKE at the time that this problem showed up. At least I have the replacement bulb to try if this problem shows up again.
Posted on Oct 09, 2008
It works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
I REMOVED THE BULB AND CLEANED OFF ALL THE DUST. THEN I GOT ALL OF THE DUST OUT FROM WHERE THE BULB SITS INSIDE THE TELEVISION. FROM THERE I RE-INSTALLED THE BULB MAKING SURE IT WAS SEATED PROPERLY, TURNED ON THE TELEVISION AND HAVN'T HAD A PROBLEM SINCE.
I have the same TV and the same problem although, its on for 20 seconds and off for 30 seconds (I timed it) consistently. Can anyone help?
Posted on Jun 18, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDF-E60A20 will turnoff (Picture & Sound) for about 25 seconds and then turn back on again. This will go on for a while. It may run for a long time then goes through this cycle again
It is clear symptoms that tv needs new lamp as old lamp has reached at end of its life.
Lamp replacement procedure is easy and would be written in user manual, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDF-E60A20 loses audio and video in a cyclical manner
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 07, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
May 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Dark screen
allrepair
thay take in ups repair
thir number is
719 687 6997
Jan 14, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
there seem to be a ic which is getting back and will soon balck out the tv.
Jun 26, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
177 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
