Question about HP Pavilion dv9000z Notebook
Loud intermitten noise
My laptop makes a noise which almost sounds like when the horn is stuck on a car, first time it happened i removed the battery and it went away and that was months ago, this weekend it happened on 3 occasions and tonight it happened again, it happens when the pc is not in use, if i disconnect the power cord it stops or the battery can u please help me with this problem, I am really concerned
    Scholar:
  • 107 Answers
this may be problem with any one stuck key in keypad
pls notic that through notepad
when noise comes just open notepad d &cheak it any alpha or numric key is stuck or not
also check with on screen keyboard witch is inbuilt in xp
start---->all programs---->Accessories----->Accessibility
if any key is stuck the keyboard display hilightly this key
if this information is useful for you please rate me......
Posted on Jun 11, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
    Problem Solver:
  • 7 Answers
Hey this issue is due to some hardware malfunction , i suggest u to take to the nearest service center and get personal advice.
Posted on Jun 15, 2008
After I park the car for a while, the horn makes noise for no reason
I know with my car, a 2003 mitsubishi eclipse, when my battery is dying/dead. The horn will sound and/or the alarm will go off. I would check reseat the cable connection on your horn and have your battery tested just for kicks. It does sound like something is shorting in your horn connection for some reason. Make sure there are no splits in the wiring.
Mar 23, 2013 | 2006 Land Rover LR3
05 ford 500 make beeping horn like noise when driving
could have stuck horn button or wire short to ground or could have faulty horn relay.
Sep 27, 2012 | Ford Cars & Trucks
Flashing dome light, broken horn, and slow windshield wipers... what can it be?
if your hearing a clicking sound when pushing the horn button then it sounds like you need to replace the horn the diaphram is probably no good.if it was a bad connection you wouldn`t hear a clicking noise.the slow wipers sounds like it could be a poor ground on the wiper motor.you can run a separate ground wire to the wiper body and if the wipers work at a normal speed then that is all you have to do.if not then the power wire needs to be checked for battery voltage if its good then the problem is likely the wiper motor itself.the flickering interior light may be the light switch maybe moving just enough to make contact to allow power to the light.make sure the switch is into the off position and see what happens.
Jan 10, 2012 | 2004 Pontiac Sunfire
97 pontiac grand am horn went out
Sounds like s dead short in the horn circuit.
Sep 27, 2017 | 1997 Pontiac Grand Am
I had some water that drip down below the space button on left side, then the laptop stereo started to make noise.. i closed the laptop and restart it. then sound was gone.., but everything else is...
Hi Jonas,
liquid has crossed/shorted some connections/contacts on the mainboard.
If it was just water, the problem should go away in a few days once the water evaporates. If not, you may need to replace the laptop.
Try this: Remove the laptop battery and shut it off. Using a can of compressed air or an air compressor (better) blast lots of air around the area where the water went in. Then put the laptop in a warm place for a couple of days and see if the water evaporates.
Please let me know if this helps.
Regards,
Joe
Jan 01, 2011 | HP Sound Card
Loud noise coming from the idle air control valve inlet tube
I do not want to be wrong with my answer but it sounds like the idle control solenoid may be buzzing or the chamber it operates in needs to be cleaned with WD40. Sometimes when a solenoid routes vacuum to a part and sticks, the vacuum is going where it never was intended to go and makes noise. You might want to look at vacuum routing or things like the air horn or if the air cleaner is connected completely around its mount.
Aug 08, 2017 | 1993 Mercury Grand Marquis
Horn Stuck
If it happens, you can just disconnect the fuse for the horn, or relay. It could be the switch underneat the airbag or clockspring.
Jun 16, 2017 | 2006 Chrysler Sebring
HP Pavilion zd8000 keyboard skips characters
The most common reason that your cursor skips around is that you are touching the touch pad when typing. Some are more sensitive than others. On my Toshiba I had that problem, but it has a Fn key that allows me to turn off the touchpad. Problem went away when I went to a mouse instead.
Had a client with a Dell with the same problem. I had to actually physically disconnect the touchpad and her problem went away.
Now as for the first problem, (the HP), I'd say you have a stuck key on the keyboard. It would make that noise.
Feb 14, 2009 | HP Pavilion zd8000 Notebook
I hear 5 warning beeps then a pause then 5 beeps again
Get the battery situated, and your beeps should go away. Sounds like an errant security horn from a sloppy connection. Interested to see what happens. TT
Jan 28, 2009 | 2001 Ford Explorer Sport Trac
2005 Chevy express Fuel pump relay meltdown 6.0L
i need diagram for fuse box 1998 chevy van
Dec 12, 2008 | 2001 Chevrolet Express
HP Pavilion dv9000z Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
