Question about Baby Trend Expedition Double Jogger
Flat tire--not fixable--is bubbling
I have just had stroller for one week and I have a flat right tire. I have tried to re-inflate, but was lumpy to begin with and is now a bubble. Need new tire asap. Please advise.
  • 1 more comment
  • lrcwac Oct 17, 2008
    Where can I find a replacement for this double jogger stroller? I need a rear wheel,it is flat and will not reinflate. Thank you!
  • blancajara Oct 23, 2008
    babytrend jogger front tire flat
  • Richard Perkins
    Richard Perkins May 11, 2010
    Please confirm make and model so we can source spares for you.
    If it is new, can you contact the supplier for spares information?
    Thank you.
    Problem Solver:
  • 9 Answers
So easy! Go to a local bike shop and they should fix it with a new tube for around $10. Or if you know how to replace a bike tire/tube or someone who does, tubes are very cheap $3-$5. Good luck to all!
Posted on Oct 25, 2008
    Genius:
  • 1,036 Answers
I advise you try the shop where it came from for a replacement tube for it.
Failing that, 'phone the manufacturer to have one sent out.
Posted on Jun 28, 2008
Hi, the tyres on my quinny buzz seem to be flat (I can press them right down with my finger) but the inner tubes are fully inflated and do not have a puncture, is this normal?
Both Bugaboo and Quinny recommended tyre inflation pressure as 15 psi / 1 bar. I find this way to soft and run my tires at 30 psi / 2 bar with no problems and far easier pushing.
Feb 08, 2011 | Quinny Buzz Three Wheel Stroller
Inflating tires on a 2000 4 plus Quinney
Hi, If you go to your local bike shop they will be able to help you. Regards marie
Mar 26, 2010 | Quinny Freestyle 4 Marina Stroller
I have an s-type jag 3litre sport reg 2001. i thought i had a puncture so i replaced the tyre, 2 weeks later flat again.the tyre guy said there could be a problem with the rim no getting a good seal i...
besides the rim problem, which he could have corrected by applying bead sealer, the stem could be defective or the rim could be cracked.
to fix a rim leak, clean the area on the tire where the tire meets the rim. make sure there are no nicks or tears along that area. clean the rim along the surface where the tiremeet the rim, no corrosion or debris. apply bead sealer to the cleaned area and mount the tire to the rim and inflate.
to check the tire for leaks, fill a spray bottle with water and add a short squirt of dishwashng liquid. over inflate the tire to about 45psi. remove the tire and lay it flat on the ground. saturate the area where the rim meets the tire. wait awhile to see if bubbles form. repeat for the other side. also spray the valve stem, tread and sidewall area. do this slowly while looking for bubbles, sraying liberally. you might need more soap in the solution depending on the concentration of the dishwashing liquid.
Mar 21, 2010 | 2001 Jaguar S-Type
Need to replace tires
try to inflate them with a hand pump first. if not you can use fix a flat. It would work perfect. There are no tires for sale for this item. Its all on keeping th emoney flow for the economy. hope this helps. You can find fix a flat at walmart target or any auto repair store
Feb 05, 2010 | Kolcraft Jeep Liberty Limited Urban...
Right front tire has gone flat 3 times in the last
You can remove the tire from the vehicle, make sure it is properly inflated, and spray with a soap and water solution. Carefully look around the bead, check the tread for bubbles, could be a puncture, and don't forget to look at the valve stem. Any bubbles indicates a leak. Good luck.
Steve
Jan 02, 2010 | 2007 Pontiac Solstice Convertible
Problem with tires ,air is escaping
Pick up a kit for bicycle repair. Take the wheel off, deflate, pull the wheel from the rim and remove the tube. Pump the tube up a little, place under water and look for the bubbles. Once you find the bubbles, patch with the bike tire repair kit, deflate, put the tube back in, reattach tire to rim and inflate.
Apr 10, 2009 | Bertini Baby Gear
Stroller flat tire
gas stations or tire places can often help fix a bicycle tire-- why not a stroller tire? shoudlnt cost more than 5-10 bucks.
if just a slow leak, you can also try a can of fix-a-flat from the auto parts store-- pump it into your tire when somewhat deflated, walk it around to let the inside get coated with the material, and then inflate it to proper levels.
Feb 01, 2009 | Phil & Teds E3 Jogger
Putting air in Bugaboo tires
You may also have a puncture.
The tyre and inner tube can be removed in the same way as a standard bicycle tyre, you can google how to remove a tyre to get some more advise.
Once you have removed the inner tube, place it in a bowl of water and try to inflate it with the pump. If you see any bubbles escaping from the tube, you have a puncture and will need to repair, again, additional advise can be found online or talk with your local bike shop for direct advise on how to do this.
If you see no bubbles you need to check that air is not escaping from the pump, if its broken then it will just vent the air as soon as you put it in.
Hope that helps
Simon
Nov 01, 2007 | Phil & Teds E3 Jogger
Baby Trend Expedition Double Jogger Logo
477 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
