Question about Logitech Z-2300 Computer Speakers
Right speaker doesnt have sound
I got these speakers about 6 months ago, and until today they have been great. i have read many similar problems but have been unable to find a solution. i believe that the problem is in the jack of the right speaker, because if i plug the right speaker into the left jack, it works. both speakers and the sub all work but whichever speaker is plugged into the right jack, (black) will have no sound. i have tested this on 2 computers and my ipod to be sure that it was the sound system that was malfunctioning
  • ReiJi Jun 14, 2008
    i fixed it, there was something wrong with the gold connector for the wired remote on the sub... i just wriggled the cord around and then i started hearing sound from the right speaker. thats for your help though :)
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Posted on Jun 11, 2008
I got the companion 3 computer speakers over a year ago and never had any problem until today. the speakers have all of a sudden been making a constant low feedback sound. i disconnected them from my...
try replacing the input cord between the speakers and the computer. the scratching noise normaly comes from a faulty connector. if that doesnt work you may have dirt or dust in contact with the speakers cones or there is an amplifier issue
Jan 29, 2011 | Bose Companion 3 Computer Speakers
Hello, my X-230 doesnt work, the power is on, the green LED light is on , but no sound, left the speaker with volume control died a few months ago, but now the other speaker and sub doesnt work too, any...
I suspect that the jack on the computer may have failed or the end of the cable that you jack in has failed. The green light indicates that power is getting to the speakers but not the sound signal. You can try repairing the cable jack prong by splicing another similar jack prong from Radio Shack, but the jack face on the mother board is a more difficult job. If you had another set of speakers you could try jacking them in to see if they operate, thus eliminating the mother board jack.
Dec 07, 2010 | Logitech X-230 Computer Speakers
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
Front speakers have no sound now.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
May 05, 2008 | Yamaha HTR-5830 Receiver
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Multimedia speakers not playing up to potential
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the excellent solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: <p> 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.<br>
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it.<br> 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up..<br> 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only. Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.<br>
5. Put the FR speaker box back together in reversed order.<br> 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again.<br>
<p> As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.<p>Thanks for giving the lead trickytrev34.
Jun 27, 2007 | Altec Lansing Multimedia Computer Speakers
Logitech Z-2300 Computer Speakers Logo
951 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
