Question about Toshiba Televison & Video
Ive got toshiba 40PW13P rear projection tv and it has convergence problem where more then one colours apear on the picture.
  • 927 Answers
Howdy,
Well, you didn't ask what you wanted but I think you should try 2 things. One; unplug TV's power cord for 5 minutes, reboot. Two go into the customers menu and try to adjust the convergence.
If these fail call a factory authorized service dealer. Good luck.
Posted on Jun 11, 2008
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
So the colours match up on the left hand side of the picture, and progressively fan out towards the right. The convergence had to be lined up manually for to come to this view. As well the picture has...
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Toshiba 50HDX82 50" Rear Projection...
I have Samsung SP42W5HF rear projection tv and
You have either a bad convergence IC on the power supply/convergence board or the whole board is bad and needs to be replaced along with doing a Full Convergence Alignment by a very experienced tech.
Apr 09, 2010 | Samsung Televison & Video
I have a double picture and the red apears to be
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 07, 2009 | JVC AV-56WP74 56" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Green convergance goes out when tv warms up tosh projection tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
STK392-110 replace with STK394-160
STK392-120 Hitachi replaces these with STK394-160, for other sets it may not be a good sub. They have been fine in the Philips sets so far.
STK392-150 replace with STK394-160
***The 394 series replaced the 392 series and is cooler running. The subs listed here are the ones that I know to work in most sets.
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
Feb 20, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba Rear Projection 42 "
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
143 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
