Question about Refrigerators
RS2544SL Did you solve your problem. I have a similar problem. The defrost sensor was already replaced without fixing the problem. Also the unit will not reboot when plugged-in due to the continuing defrost sensor signal on the front door panel. Do you have any suggestions? Thank you Tom
I have to take the rear freezer panel off everry few days and defrost it that way, not a solution, but I'm waiting for a reply from Samsung they "did not recieve" my first fax.
Posted on Jun 17, 2008
I have a LG air conditioner which seems stuck on defrost. It works fine in cooling but when on heat the defrost light comes.
Possibly a stuck or closed defrost sensor. The sensor gets to freezing which closes the switch. So the unit goes into defrost cycle which switches the flow of the freon on a Heatpump. The hot gas thaws the coil and the sensor. Which opens the switch and switches it back. I'm giving this answer without knowing more about the unit. Defrost light comes on & it doesn't run at all? LG system is a split unit or window unit or what?
Feb 19, 2017 | LG Heating & Cooling
Samsung RS2544SL/XAA getting iced and freezing
In freezers if it's getting ice inside body surface? Sometimes refrigerators doesn't defrost ice completely and shut the drain water line of defrosted ice. If you doesn't have checking instruments for defrosting heater element and other parts, there id's wary wary to defrost ice once completely once. Thank you
Oct 17, 2016 | Samsung Refrigerators
Ice cube machine going into defrost/harvest mode without having ice.
Inside the bin there is a photoelectric sensor that senses the level of ice in the bin. This sensor can be knocked out of alignment in time which will send false signals to the controller. Re aim the sensor and make sure it is tight. This may solve the problem.
Feb 21, 2014 | Scotsman Cooled Modular Contour Cuber Air...
Unit doesnt seem to be removing humidity. its
Check the auto defrost sensor. They are known to become defective. Bypass or remove the device and unit will run normally, almost. WARNING: without the defrost sensor the unit will tend to ice up in cooler ambient environments. If sensor is removed watch carefully and only use in summer months. The dehumidifier may also be fixed by replacing the sensor but the design for repair is different and requires a costly modification.
Jul 17, 2010 | GE AHG40LJ Dehumidifier
The car bucks and dies after it gets warmed up and gives me code P1391 how do i fix it?
P1391=Intermittent loss of CMP or CKP,
Thats the cam sensor or crank sensor,
Jan 14, 2010 | 1999 Dodge Intrepid
Leaks water inside the refrigirator part. It ices and eventually leaks to the bottom part! We keep the fridge at a normal temperature! 38degrees. please help! is there a recall to solve the problem!
The unit has an automatic defrost system that defrosts the fridge automatically when frost develops or when certain conditions are met.
  1. Defrosting starts when the compressor running time reaches 4 hours after a power outage or after the unit is turned on for the first time.
  2. Defrosting starts each time the compressor running time reaches 7 hours.
  3. Defrosting stops if the sensor temperature reaches 46.4°F(8°C) or more. If the sensor doesn’t reach 46.4°F(8°C) in
    2 hours, the defrost mode is malfunctioning.
  4. Defrosting will not function if its sensor is defective or wires are cut or short circuited.
If your unit defrosts frequently even when the conditions above are not met, you have a malfunctioning sensor. You may have to ask the help of a qualified technician to disassemble and:
  1. Check the connections of the sensor to the control board.
  2. Inspect the wires for short or cut wire.
  3. Push the reset button on the main board.
  4. Replace the sensor control assembly.
Nov 04, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Freezer side stops defrosting.
has the defrost timer been replaced? if not, that'd be the next step. there are only a few parts in that line: the power, the sensor, the timer, and the heating element. also, if the condesate drain is plugged, water stays pooled under the coils and freezes again.
Aug 27, 2009 | Refrigerators
Er IF code
IF is the Ice Fan failure code.  The fan that sends cold air to the ice maker is frozen.  Unplugging and defrosting does not solve the problem.  Mine was fixed as a warranty item when I complained to LG since I had a similar problem earlier with the refrigerator fan within the warranty period.  The fix consists of replacing the ice maker fan and housing (the new housing has a drain hole to prevent freeze-up), replacing the freezer duct housing (again with design improvements), and a new control board (presumably with new defrost programming).
Jun 05, 2009 | LG LRFC25750 Refrigerator French Door
Frigde wont get cold but freezer does.
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Dec 29, 2008 | Samsung RS2630SH Side by Side Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
