Question about LG LRBC22544 Bottom Freezer Refrigerator
Water Dispensor Problem
I own the LG Bottom Freezer LRBC22544ST Refrigerator. Up to this point it has operated flawlessly. Recently the button on the water dispensor has been sticking when depressed. Is there a way to fix or replace this button? Any recommendations as to what is causing the button to stick.
  • kmoney6026 Jun 17, 2008
    I will give it a whirl. Thanks for the suggestion!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
There is a little lever behind the water dispenser that may be sticking and or broken. You do have to take the panel off to access it. It is a real pain to do and most times you take it off the clips break and you have to replace the complete piece. If you go real slow you may be able to get it off without it breaking. If you look at the bottom of the dispenser there are 2 notches, carefully use a flat screwdriver and start there, get the bottom off and then work your way up. Good luck it is tricky.
Sgt 48
Posted on Jun 11, 2008
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Water/Ice Dispensor Malfunction
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure the refrigerator has the blower problem for which the problem arrises ....... please visit your service authority...........have a nice day:-)
Mar 02, 2009 | LG LRSC26920TT Side by Side Refrigerator
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Dispensor not working
Check the electrical connector at the bottom of the freezer door , this can corrode and develop a poor connection
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG Refrigerator LRBC22544st
Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
Aug 28, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Jul 13, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
257 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
