Question about LG Flatron L1811S 18.1" LCD Monitor
I have a complicated scratch
My lcd monitor has an scratch that was made by an pen
i erase the most of it but it still remains on the interior of the scrath ,i also tried the vaseline technique that worked for most of the sracht but it still remain ink on the scrath that wont come off
please a need help
P-S:please see if you can find homemade solution
thanks
Afrer power on, i can see the screen 1/2s and afrer the screen remain black.
Try to check your RAM, is it in working condition or not, If yes, then remove it from your CPU, rub with an eraser, then fix it again.
Sep 23, 2015 | AG Neovo X-15AV 15 LCD Monitor - X-15AV-R
There is a large scratch on the screen, and appears black when the monitor is on. My monitor fell and hit the edge of a shelf because I had it leaning forward too much. Obviously, the mark is deep, and the...
It is evident that the LCD panel of the monitor is damaged. If your computer has Dell complete care you can get the monitor replaced. If not you can contact a local technician and get the LCP panel changed, with the remaining circuit boards and backlight assembly intact.
Jan 27, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Black vertical mark on computer
    If it is an LCD monitor it sounds like the monitor got cracked when you moved it. Either that or one of the edge connectors has gotten damaged and is causing a dead column of pixels.
    One other possibility is a bad video card or video cable, hook the monitor up to another computer and see if the line is still there, if not, video card or cable. If line is still there then there is either a crack or bad edge connector. Crack there is no fix, except a new monitor. Edge connectors can sometimes be repaired by the appropriate service technician.
    Good luck
    May 10, 2009 | Computers & Internet
    Scratched Finish on Screen While Cleaning
    Here are some solutions to consider. Try in an inconspicuous place first.
    1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
    2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
    3)You may also get commercial LCD scratch removers on the 'net.
    An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
    Mar 13, 2009 | Sony Televison & Video
    Sctratches on 46" lcd tv. Two of which is noticeable in dark scenes.(White lines) How do I fix this?
    used thse methods myself
    Vaseline Method
    1. Clean the surface of the screen.
    2. Take some Vaseline and fill the scratch with it.
    3. Gently wipe off the excess Vaseline, being careful not to press too deeply so as to leave some inside the scratch.
    4. Voila. This works because the optical density more closely matches the LCD face than air.
    Pencil Eraser Method
    1. Find a pencil with a clean, soft eraser. It must have no pencil graphite on it as you won't want to smudge that on your monitor.
    2. Lightly rub the eraser over the scratch or nick on the screen.
    3. Keep rubbing until the scratch completely disappears
    Oct 01, 2008 | Televison & Video
    Scratched lcd screen - 52inch sony bravia
    Vaseline Method
    1. Clean the screen
    Neither is a perfect fix but does help alot
    LB
    Sep 21, 2008 | Televison & Video
    Scratches in my LCD Television Screen (sony bravia) How will I fix this?
    Easiest solution is the stuff you buy to fix your glasses with (Lens cpr), so long as it's a small scratch. Larger scratches don't try to fix you can damage the screen further.
    Other solutions (though I recommend only at your own risk)
    Vaseline Method
    Keep rubbing until the scratch completely disappears [1].
    Sep 02, 2008 | Televison & Video
    Repaire scratches on a lcd flat screen
    The eraser method is even better than I first thought.
    I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
    Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
    -So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
    Apr 25, 2008 | Computers & Internet
    LG Flatron L1811S 18.1" LCD Monitor Logo
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
