Soyo DYLTO32A 32 in. HD-Ready LCD Television Logo
Posted on Oct 30, 2010
We have lost our picture.. We can hear the audio. I changed the TV to a Direct TV coaxial hookup. Nothing...
2answers
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
1helpful
My 50Hda39 50 in plasma doesn't work through the coaxial cable hook up
Please contact the authrized service center for Hitachi. Sounds like corrupted firmware. Firmware update is necessary, and the firmware to Hitachi is very difficult to get by internet. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
It wont pick up my tv audio out
We could use some details regarding audio hookups and your TV if you consider it a sound source.
Analog or digital???
http://www.retrevo.com/s/RCA-RT2660-Receivers-review-manual/id/19241bh051/t/1-2/
Page 14 shows wher analog audio could go. And/or you could bring in digital audio if the TV has an output for it (page 5) and select the appropriate Coaxial or Optical input.
Coaxial cable
Most newr TV's do not come with a coaxial hookup anymore, you either need to use RCA cables for Audio and Video, Component Video, S-Video Jack, Digital Audio Jack or HDMI Input.
2helpful
Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
2helpful
2answers
Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
