GEneral protection fault
I'm trying to install windows xp professsional on a computer after Fdisk.As soon as the machine starts to boot from the CD i get this error,general protection fault and i can't get it to install.What is the cause?
  • 2 more comments
  • gofish65 Jun 13, 2008
    The HD was OK would you believe it was the XP disk itself.Ichanged to another disc and it booted right away.Who knew.
    OK the solution was to change the CD I was using.The computer booted write away after that, thanks,thats one to remember.
  • Marty marty May 11, 2010
    one sure cure is a new hard drive, but you can work around this one depending on your skill level. I assume you did format and SYS the disk to XP, right?
    Have you tried to run setup from the DOS prompt instead of CD boot?
    You also can low-level format the hard drive to get it back to factory conditions if you answered yes to all questions so far.
    there also is a possibility of a virus.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What happens when you reformat the hard drive and then reinstall?
  • 114 Answers
You probably should get a new HD like 24 seven mentioned. It's your best bet. But youo should try to get like a 10GB HD off Ebay just to test. If it works from there, Get whatever size HD you want.
Posted on Jun 11, 2008
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Whant to know how to partition
Windows XP provides partitioning functions within the administrator tools, Disk Management. Windows 98 SE provides a program called FDISK. You boot your computer with the win98 cd in the cd-rom, and select start computer with cd support. At the prompt, type in FDISK.
Otherwise you need a disk paritioning software like partition magic
Jun 03, 2009 | HP Computers & Internet
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
Apr 30, 2009 | Dell Microsoft Windows XP Home Edition
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
'GENRAL PROTECTION FAULT'error seen when pc boot with xp
This is what the error says ?
Trap 0000000D =========== General Protection Fault ============
tr=0028 cr0=00000011 cr2=00000000 cr3=00000000
gdt limit=03FF base=00017000 idt limit=07FF base=000017400
cs:eip=0008:2FFF3066 ss:esp=0010:00060E7B errcode=0000
flags=00010013 Cy NoZr IntDis Down TrapDis
eax=00000F44 ebx=00000004 ecx=00000005 edx=00000000 ds=0010 es=0010
edi=00070000 esi=000000A1 ebp=00000000 cr0=00000011 fs=0030 gs=0000
The boot loader files are either corrupted or missing.
To repair this problem,try boot with the Windows XP CD-ROM
and choose the option to install. On the next screen, choose
repair to repair your Windows installation. When the repair
process is finished, you will be able to boot back into your
operating system without losing data or having to reinstall
software.
Jan 01, 2009 | IBM P4 3.2/512/40/CD/XPP DT M-Class...
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Cant install xp on my maxtor SATA 6V160E0 UDMA6
*If you have access to another computer with a cd burner*
One way is to download the universal boot cd, boot a linux rescue disk image from it and use fdisk to remove all partitions.
This way the disk will be seen by windows setup again.
This is a silly bug in windows setup i've discovered a long time ago. When it does not understand the partitions on a disc it just hangs during the setup screen.
Download the iso image from http://www.ultimatebootcd.com/download.html then burn the iso image to a blank cd. Put it in your dead machine's cd drive and boot from it. Then choose one of the linux boot options.
When linux is up and running type fdisk ENTER
Then press p and a list of partitions comes up
Press d (delete) and then the number you see after /dev/hda etc.
Do this for every partition you see listed or just for
the first if there is data on the second/third/etc..
Press w (write) q (quit) and reboot with the windows cd in place.
p.s. This does irreversably remove
partitions and data on the disk!
Jan 11, 2008 | Maxtor Hard Drive
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Compaq Presario 5102US with uWave2 motherboard just want to fdisk & reformate
If you need to install XP, you need to get into the cmos settings and in the standard settings enable your cd drive as the first boot device, save setings and exit. Put the XP cd in your drive before you boot the pc, then when on the screen you are prompted to press enter to boot from cd, it will then go through the installation process and ask if you want to format in fat32 or NTFS, the later is the norm for XP. You can delete or set up partitions and format using the cd you do not need to use fdisk as XP does not use it unless you format with a win98 cd
Apr 24, 2007 | Compaq CPQ/Presario5006EA uWave2 K7...
Computers & Internet Logo
815 people viewed this question
David Payne
David Payne
