Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
  • broken1toe Jun 11, 2008
    i checked device manager but the cdrom is not listed there...thought the light blinks also it is not listed under my computer
  • sultangeek Jun 25, 2008
    Satellite 1135-s155 laptop I have the same problem also. Device manager
    shows everything fine. i can eject it from my computer. I have the
    latest firmware updates. it shows up in the cmos and if I refresh the
    Rom window it blinks. i have installed all the drivers. i have been so
    far as to go to intell and reinstall all the chip drivers since it's
    controlled by one of their IDE drivers. I have all the codec's
    installed. I have pluged it in while xp was running and it pluged and
    played right in but still nothing Toshiba drivers
    Thx
  • 8,596 Answers
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Posted on Jun 11, 2008
Just got second hand ferrari 1100 and it just has black screen?Used F8 to get the harddrive light and put CD in which is spinning but still black creen also tried external screen?HELP PLSE?
If your external monitor isn't working, it may be your graphics. You could open the case and search for loose connections or components. It's difficult to say without opening the laptop. Your specs say you have integrated graphics. What kind of noises? Is it coming from the HDD? the DVD rom?
Dec 07, 2012 | Acer Ferrari 1100 Notebook
CD rom not responding does not spin, play or eject
the cd player has gone bad. make sure you have it set to cd for sometime's things get alil stuck
Jan 12, 2010 | Nakamichi SoundSpace 5 Shelf System
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dvd-cd rw drive
This means that your CD-rom drive does not read the CD, it could be that the CD is a different format (DVD, for example) or the lens is dirty or Your drive is faulty. see if your drive is compact or dvd and try the right formats. Try clean your CD-drive lens. If all this does not fix the problem, your drive is faulty. And needs repair.
Oct 31, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Cd-rom drive
Hey Dale,
It sounds like there is an issue with the laser in the CD-ROM drive because it spins for 10 seconds trying to read the disk and stops because it cannot. If you try and put another disk in and it does this then the CD-ROM is bad. You can find replacements online for reasonable prices. You can also go to most electronic stores to purchase a replacement. They usually run around $30 dollars or less.
Thanks - Tech101
Jun 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Samsung cd-rw drive sh-r522 problem
IF THE DRIVE SHOWS IT ,, then its hardware
eighter the drive is defective or something is wrong with the MB/P
try the drive on a different computer if it works change your mother board format and reinstall
if it didnt work take it back for warrenty or get a new drive
Dec 09, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
