1) remove all screws from the back of the unit
2) remove the keyboard by pressing the tabs above it, which hold it in
3) remove all the screws from under the keyboard
4) disconnect the ribbon cable from the touch pad
5) unsnap the edges around the top of the case, and remove
6) cmos battery will be in the lower left corner
See picture: http://i.imgur.com/B4zrj.jpg
Do you know what the model of the battery is before I take apart the machine?
thank you for the picture!!!!
I read in another site that the model of the battery is:
3 volt lithium ML1220 (Panasonic) rechargeable
Thanks for your advice. It was a challenge pulling it apart! Ordering the battery through ebay, and will see what happens...
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
SOURCE: is the cmos battery rechargable y the Asus Eee PC
It should be a "trickle" charge, i.e., just turn it on, and a small amount of current will be used to recharge the CMOS battery, in the same way that driving your car recharges your car's battery.
SOURCE: Hi - What is the life-expectancy for the ASUS Eee
The BIOS battery should last 2+ years.
Testimonial: "Thank you for your kind assistance. Your response is truly fantastic!"
