Question about Biostar P4M80-M4 Motherboard
Biostar motherboard or processor dead?
Thanks for info. However, I tried a good power supply but its the same problem. When I turn on power only fans (CPU and case - both plug directly to motherboard) spins. No other sounds. Also floppy drive light comes on immediately and stays on (and floppy cable is plugged correctly). I want to think it may be the motherboard or processor. Any other ideas?
    Novelist:
    Scholar:
  • 160 Answers
Your CPU might be overheating, and the system is shutting down.
I just went thru this with my computer (same mobo).
No messages or beeps, just yellow light on front of case.
In my case the dust built up enough to hamper cooling.
Make sure you vacuum & blow out any dust inside.
Hope this helps.
Posted on Jul 15, 2008
  • 31 Answers
Have you also tried different video cards? or the onboard built into your motherboard?
Posted on Jun 11, 2008
Unplug hard drive, no beeps? Unplug CD-ROM, no beeps? Remove RAM, no beeps? 85% it's the MOBO. Static, surge or just plain dead (and cheap).
Posted on Sep 01, 2008
Power box voltage
It isn't a guessing game, Dave.
Suggest use a Power Supply Wattage Calculator, and be SURE,
http://support.asus.com/PowerSupply.aspx?SLanguage=en
http://extreme.outervision.com/psucalculatorlite.jsp
Need guidance in using either one, post back in a Comment.
Need all the specs. (Motherboard, {Biostar}, Processor, Ram Memory, graphics card (IF used), how many fans, how many optical drives, (CD/DVD drive), etc.
Regards,
joecoolvette
Dec 27, 2012 | Biostar MCP6P M2+ 6.x Motherboard
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
Mainboard: g31 m7 te - power: antec hcg750 - gpu: gtx560ti
No the mobo is compatible with the Power Supply, and GPU.
And vice-versa.
Mainboard fan???????
You mean the Processor (CPU) fan?
I'm guessing I guess, because computer case fans aren't on the motherboard/mainboard/mobo.
(MOtherBOard)
You're getting power to the mobo, but the question is how much?
1) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
http://206.108.48.60/app/en/mb/introduction.php?S_ID=363&tab=1
The mobo will support Intel Core2 Quad-Core processors. Depending on which one, you may be talking about Up To 105 Watts of power,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Quad-Core_Desktop_processors
This is why LED's can light, and fans may spin, but the Processor isn't getting enough power, so the computer will not turn on. (Processor isn't turning on)
Why?
1) Just because that Power Supply is new, doesn't mean it is good.
Sometimes you get a bad one. Test the three main voltages coming out, with a multimeter set to DC Voltage.
Need guidance post back in a Comment.
(An economical multimeter can be purchased, for as little as $8 to $12. I have seen cheaper. Available in a multitude of stores. An auto parts store is but one example )
2) You don't have the 4-pin ATX +12 Volt power cable plugged in.
Goes to the white square 4-socket hole connector, to the left top corner of the Processor socket.
(Motherboard installed in computer case)
3) REQUIRES -> TWO 6-pin PCI-Express power cables, for the Nvidia GTX560Ti graphics card.
The Antec HCG750 PSU has 4 of them, so no problem there, IF you have two of them plugged into the graphics card.
Both connectors of the 20 + 4-pin ATX main power cable's connector, need to be used. Biostar mobo requires a 24-pin ATX main power cable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
Post back in a Comment as to power cables plugged in, and DC Voltage test on PSU.
Regards,
joecoolvette
Aug 06, 2012 | Biostar G31-M7 TE Motherboard
I just got my Biostar A780L and i put a amd phenom 2 2.8ghz 920 quad core in it and when i try to start it up it sounds like its working but the screen just stays blank, like the monitor doesent even turn...
No noise, no beeps whatsoever?
If no beeps, MBoard may be defective, or RAM might be bad, maybe one of the drives.
You need to d differential diagnosis.
Try removing everything but the CPU and see if it will POST.
If so, add 1 stick RAM, then 2nd stick, then Drive, then ,,,,,, until you find culprit.
If nothing works, would try another "known good" power supply
If that is no go, Mboard bad.
Feb 04, 2011 | Biostar A780L Motherboard w/ AMD Athlon X2...
Hello I have a problem, my motherboard g31-m7 no video, i picked up the battery, but the problem still there, how to solve this problem?
I don't know who recommended a CMOS battery to fix your graphics, but this = no.
1) You have checked the monitor cable, correct? If the monitor cable is removable, replace it with a known to be good one, for a test.
If the monitor cable is not removable, use a known to be good monitor, and cable for a test.
2) If you are using the Integrated Graphics of the motherboard, (OnBoard graphics), then the next test is to install a graphics card. If you have graphics now, your OnBoard (Integrated) graphics chipset is bad.
3) I find most of the time, (Like around 80% or more) that the Power Supply is bad.
Enough power to light LED lights, spin fans, (Or spin a few times, and stop), but NOT enough power to turn the Processor on.
A bad Power Supply is one of the leading causes of computer failure, right next to computer is dirty inside.
A) ALL of the LED lights being on at once, will use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
Here you can see a CPU Support list for the Biostar G31-M7-TE motherboard, and the wattage of the different CPU's,
http://www.biostar.com.tw/app/en/mb/cpu_support.php?S_ID=363
Again, you may have a bad Power Supply.
Enough power to light LED lights, and spin fans, but not enough power to turn the Processor on.
No Processor operating, No computer.
No computer operating, No video signal.
(No Signal)
Do you have a KNOWN to be good, compatible power supply to use for a test unit?
Post back in a Comment.
Nov 06, 2010 | Biostar G31-M7 TE Motherboard
No display even after the system boots
You either have a dead CPU or a dead motherboard or a partially-dead power-supply -- the power-supply should supply different voltages to different computers, i.e., one voltage to spin fans, and a different voltage to power the RAM, and a different voltage to power the motherboard. So, it can be "partially" dead.
Borrow a power-supply, and try that first.
If all else fails, take the computer to a qualified technician.
May 31, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Motherboard failure
The MB failed - you may have warranty on it; check with the place where it was bought.
Feb 04, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Mother board reset buttom?
I assume you have the fan of your power supply working indicating that power is OK.
Disconnect everything from the motherboard leaving only the processor, fan and power. If you don't hear any beep means that you have a problem with either the motherboard or the processor.
PS Verify compatibility of motherboard FSB and processor.
Oct 19, 2007 | Biostar computers10: Main Board...
Biostar P4M80-M4 Motherboard Logo
170 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
