Question about Epson Stylus C43SX InkJet Printer
C43sx both lights on
Turning on the printer, the head moves a little bit to the left then red light on (not blinking). Pushing paper/ink button , head move to left again.... and again.... and again. Replace new Ink cartridge both black and color same problem. Counter reseting.... not work. Any idea?
thanks jez Turning on the printer, the head moves a little bit to the left then red light on (not blinking). Pushing paper/ink button , head move to left again.... and again.... and again. Replace new Ink cartridge both black and color same problem. Counter reseting.... not work. Any idea?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The ink and paper lights are blinking and the power light is not lit
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the flashing lights (Epson R1800) too. Both the ink and paper flashed rapidly at the same time.
After intense searching on the net, I tried just about everything. SSC service utility did
Nothing. Turning printer off and on also didn’t help.
Turning printer off then pressing the paper and ink buttons, then turning power on, then waiting for both lights to flash, releasing them and pressing the ink button for 10 seconds also didn’t help.
After days of this I got frustrated, packed the POS back into the box and put it up for sale
On Craigslist. No takers… I was about to put it out to the curb ($540 printer sat in the box for almost a year) but decided to do one last google and found someone talking about the print head moving along the rail.
Suggestion was to turn printer off and see if print head traveled freely back and forth. Ok I thought, Pulled the printer back out of the box and set it up again. Reinstalled software and turned it on. Red lights flashing again! Ok, press the ink button to move head to home, then turn printer off. Then I tried to move head along rail. It moved freely a couple of inches to the left then stopped like something was blocking it.
Took my flashlight out and could not see anything in the way so pushed down on the cartridge cover and heard a “click”….. Duh! The freakin’ cover was not closed! Now the head would move left and right all the way so I turned the printer on and to my amazement NO more flashing red lights! I was both thrilled and depressed (at my stupidity) for not seeing this earlier.
I will post this everywhere I can to remind people that the cartridge cover is the FIRST thing you should check upon seeing both red lights flashing rapidly!!!!!
Apr 29, 2010 | Epson Stylus Photo R1800 InkJet Printer
Red light is always on
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
The error light on the C43sx is quite "non-descriptive". It simply means there is an error - that error depends upon the flashing/timing of the light.
I suggest you get hold of the Epson service software to get a better idea of the problem. It is quite possible the machine has simply hit the ink overflow protection counter limit, which is easy to fix with the above software. It is also possible the machine has a fatal error in which case the trash bin beckons.
Visit this person for a source of the software and more help.
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
change the cartridge thats simple red light indicating you must change your catridge
Ink cartridge carrier jam
Once it jams on the left turn off the machine. usually my lights are all red at that point, one is blinking the other two are solid red. open the cover. shine a flashlight in there, you will see a clear or light grey plastic ribbon that runs from the left to the right. it is the top most thing. Very carefully, clean it with a paper towel and a little water. or a kleenex. it should be almost clear.
after done, move the cartridge head to the right without turning on the printer. once again, clean the clear plastic ribbon where the cartridge head was located. finally turn on the printer, when it stops initializing, click the paper feed button, if you were successful, you won't see it jam into the left side.
if not, try repeating again. I think the optical head could also have some junk on it, and will deposit it back on the clear grey plastic strip.
the clear strip passes through the cartridge head. I'm told it is called an encoder strip and the optical head reads the strip to know it's position.
when that strip is dirty or covered with some ink spots, the print/cartridge head, can't read it and slams into the side the the printer.
this happened to my c80 at least 3 times now in seven years.
Feb 09, 2008 | Apple Epson Stylus C80 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
Nov 15, 2007 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
