Question about Starbucks Saeco Italia Digital Barista Coffee Machine
"NEED TO PRIME" alert is on. Have run a couple of tanks of water through the wand making hot water, but still says NEED TO PRIME. The pressure on the water seems a little lower than normal. Tried to decalsify, but that program won't work either, it starts, runs for about 10 seconds, then says it is done decalsifiing and needs to be rinsed, which again lasts for about 10 seconds. Afterward, machine still says NEED TO PRIME.
  • Luciano Marquez Dec 04, 2008
    yes, my machine warms up but never starts. Low water light blinks but it won't prime. Service center said you need a new pump. About $150.00 parts and labor.
  • Anonymous Dec 08, 2008
    I have the same problem says it needs to prime all the time if I mess with the buttons and turn it off and on a few times it will wrok for a cup or to and them it will do it again
You need a new pump, cost is about $150.00 parts and labor.
Posted on Dec 04, 2008
  • 40 Answers
That message indicates that water lines may be dirty. How long ago or how often had you descales your machine? If you have not routinely descaled then the water lines have to be cleaned ( by opening the machine) manually and/or replaced. Another possibility if you have been descaling it regularly, is that a water line may have small crack. And yet another possibility is that the pump may be going bad and/or the flow meter is clogged ( needs cleaning and/.or replacement). Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
Hey i want to descale my machine.. how do i do this? does it need to run through the machine as hot water and steam through the wand? Cheers Catherine
Hi
With the proper descaling media ( not vinegar) mixed in your water tank. Turn the machine on and run water through the wand immediately, then turn off the wand and let it run through the brew head for a couple (8) of seconds then open the wand again for a couple (8)seconds, then turn off the machine and let it set for 15 minutes. Repeat this procedure until the tank is empty. Then rinse everything out and repeat this procedure with out turning the machine off. Just open and close the knob every 8-10 seconds until the tank is empty again. Have something under the brew head and wand to catch the water. Yo can stop the process to empty the containers is they get too full.
Jan 06, 2011 | Saeco VIA Venezia
Type: sup 015 st no water passes during rinse or
First, check / remove the water filter in the tank, next try to run hot water thru the wand, not steam but water, this should prime the system, then turn off and back on, that should do the trick, unless you have a bad pump. Good Luck!
Jun 27, 2010 | Saeco Stratos Coffee Maker, Espresso...
Trobleshooting saeco coffee machine
with the water tank fill open the steam wand with hot water setting to re-prime the system or ventilate it
Dec 13, 2009 | Saeco Aroma Espresso Machine
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
The machine lights don't turn on
sounds like you need to prime the machine. check the manual for those instructions. if (like us) nothing happens, then read on:
johnshami had this solution on another post, and it worked for us when the manual's instructions to "prime" the machine resulted in no water leaving the tank to enter the machine:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
The blue light is blinking, the water tank is full, but the water isn't heating up at all. should we return it? Or is there something that we missed? We followed the instructions and are getting no where.
Aug 09, 2009 | Saeco Starbucks Sirena Espresso Machine
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
512 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
