Question about Amana Refrigerators
My Amana side-by-side does not cool enough. It seems blower keep running. I put the control knob at highest, but still cannot make ice. To make ice freezer should be atleast 12F to get the cycle started. Any suggestion. Refrigerator temp is about 45F, which is slightly higher. Any help, what could be wrong? 27 cubic ft model sxd27q2w
  • 2 more comments
  • pramod22 Jun 11, 2008
    where is thermostate located? how I can change?
    I have owners manual (1994), cannot find the location of it on page 33 where entire picture of each part listed.Doesn't mention thermosate in troubleshoot pages
    I know how to replace such parts as long as I can find it without much trouble. I fixed my gas furnace, water heater, cloth dryer, washer and many other items. I need to get the exact location of thermostate. I have volt meter etc.
    Model # SXD 27Q2W (manufacturer part # P1181313W)
    Make: Amana
    Side-by side
    I said in my reply that setting is at 6 to freezer & refrigerator highest is 7. Til yesterday we were only using 2/4. When it not cooling, very first thing in my mind as setting. It has been 18 hrs and still same thing. Not a good help from you. Thanks.
    I am happy and don't want any more help. Things you are telling I have already done. Please don't charge me as I am happy with your response. Thanks.
  • 1,894 Answers
Think this thermostat has failed
Posted on Jun 11, 2008
  • 5 more comments
  • dewan nafees ahmed Jun 11, 2008
    you wil probably need to change the thermostat of ur unit.
    on side of the unit.
    very simply.
    need to detatch it from your unit carefully.
    then order the same from shop.
    then replace it and connect it to ur unit again.
    but see to that you perform this only with a prior knowledge of electrical and electronics.
    else there is a risk of shock,
    be careful.
    these diagrams belong to one of our co-expert named bobotfel
    place from where you can buy the part.
    is this
    and one more similar instance mentioned in another site is.
    it is great to know that you fix you own appliances. only a few people do it.
    feels good to assist customers like you
    thank you
Amana PTAC PTH093E Fan runs at single speed only regardless of setting-auto/low/high Hot or cool air is coming out so compressor/heat coil is working. Reset unit and replaced fan motor-no change.
I've replaced many Amanda control boards. They have micro relays attached to the board. These relays are about a half inch by 1 inch in size, and control line voltage to the compressor and blower motor, and give up quite often. Its probably the board if its a digital controlled board. If it has manual, turn to select, type knob, it will be in that fan section knob. Hope this helps!
Mar 13, 2017 | Amana Heating & Cooling
I work at a holliday inn express and we have a lot of amana ac units and the problem we keep having in the summer is they freeze up with ice or fill up with water and leak all over the carpet. so im...
Yes, the client is keeping the unit on too cold. In my opinion, this design is wrong, wrong, wrong. When a user is not cool enough they turn the unit colder, and cause this icing up.
The best design keeps the evaporator coils above freezing at all times, automatically. Users have no idea and really cannot be expected to understand this issue.
Cars did the same thing (even Mercedes), and it is just nuts. If I was in your position, I would seek to have amana make a modification kit that would sense the evaporator temperature and interrupt the compressor until the temperature rises enough to keep icing under control. Under that scenario, max is max, period, but the unit will put out cold at all times, rather than icing up.
Jun 21, 2011 | Amana PTC093B35AJ Air Conditioner
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 10, 2008 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Amana bottom freezer
Hello ghilitho, what you are having is an issue with the defrost cycle. There are 3 parts to this, heater, thermosat,and timer. Sometimes on the newer units the timer is the electronic control. What you are seeing is after you defrost the unit, it works for a time, this is because the evap fan pushes the air thru the unit. With the evap coil froze solid, the cooling drops. You will need a ohm meter to check the heater and thermosat, the heater & thermosat should show to be closed. Also make sure if this unit has a over heat thermosat that it is closed. It may have open up. If all this is good, then the timer is the issue. Hope this helps
Jan 28, 2008 | Refrigerators
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
76 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
